Wanted - Steering Box Bolts and Lower Flang Coupling
Started by Dave DND, February 10, 2024, 05:44:59 PM
Buggers
I am looking for a couple of Steering Box mounting Bolts that Clamp the box to the front beam - part number is N0104481  and nobody seems to have any?
They seem to be a strange thread pitch and cannot find anything else that fits?
Also looking for the steering Box lower Flange clamp - this is the bit that goes on the end of the steering box shaft and below the rubber ring - I want an old fasioned bare metal one with good internal threads rather than a new one that for some reason all seem to have been chrome plated.
Anyone have anything kicking about please?   :-\
Dave...   avoid the repro one... It is not fit for purpose....  The bolts..... these will be a 10.9 tensile standard metric shoulder bolt of either 1.5 or the finer 1.0 pitch. I have fitted a fair few over the years and never had cause to seek any other thread type. Make sure they are torqued correctly and as belt and braces use the specific  lock tab washers.
Quote from: Paul1953 on February 10, 2024, 06:12:57 PM
Assuming you mean the flange?  I actually want a real one as probably going to be sticking it in the lathe anyway to make an adaptor out of it
1.5 pitch doesn't want to fit which is what has thrown me a bit - definitely not finer though
I`m guessing its an oddball size as many sites list them by part number, but all out of stock - if it were a normal type bolt then I would not have expected to be a problem getting them?
HUDGE BUGGY
GP Mk2 Super Buggy LWB
MEGABUG not got old / reconditioned items ??????
#4
The bolts are generally M10 x 1.5 mm pitch x 48mm but I have one box in my collection that isn't, it looks a similar pitch but slightly smaller diameter.
I'd swear it's 3/8" unc but I haven't got a bolt to try in it. Possibly a pattern TRW box of US origin still using Imperial fasteners?
Edit: Yes, definitely 3/8 unc, damn Yankees!
So that'll make them 3/8 unc by about 1 3/4" long.
Quote from: Manxdavid on February 10, 2024, 10:08:33 PM
Well that was a surprise as I always thought Beetle stuff was Metric  ???
However, just pulled a 3/8 unc bolt from my Bike (US Import) and it fits a treat  ;-)up
Nice one, wouldn't have thought of that   ;-)(-;
I just looked in daylight and surprisingly it's a genuine VW box that has the unc threads, most odd  :-\
The US derived (if not made) TRW box has regular M10 threads.
Just dug out an old knackered rusty but genuine VW box here, and that uses the same UNC bolts too
that makes sense though, as instead of listing a metric bolt size, everyone's websites just say out of stock -
seen some silly prices for them too using the VW part number, anything up to £6 each + shipping !!   ;D
Now I know its a standard bolt, I can rummage around the garage for one - my old GMC used to drop them all over the yard, so one of them must fit  ;)
Still hunting for that flange though  ???
I had a good hunt but can only find the opposite one with the male splines. Sorry!
£3.25 for 2 with free shipping?
#9
I found a flange if any good? When you say 'good internal threads' I'm not quite with you. They're smooth inside, the only splines are on the shaft, any that look splined have just picked up 'witness marks'.
Just message me your address of you want it.
Yes please mate - perfect   ;-)up
I didn't realise they were smooth inside - I thought splined to match the outer  ???
That makes my life even easier then - PM incoming   ;-)up
Thanks for the spot Krug, but most of the aftermarket ones seem to be made from cheesium which is why I was after a genuine one.
Now solved thanks to the kindness from ManxDavid in sending me one to play with   ;-)up
How much???
'kinell!!!  :-\ :-\ :-\
Parts prices are getting silly 3mm x 22mm screws for indicator switch £2.50 each I got 12 plus postage for less than £8
