Toms fugitive 4
Started by Johnthesparky, May 23, 2017, 05:36:42 PM
Johnthesparky
UVA fugitive 4
We've carried on plodding away,
Sorted some back tyres for the slot mags
Fitted a floor, mounted the seats and fuel tank, we've rebuilt the brakes and they are ready once we've sorted the brakelines.
We've had a play about with the mudguards and positions for the headlights too....
So it is moving forwards slowly
Johnthesparky
UVA fugitive 4
Merry Christmas, have a happy new year!!   8) :)
Nothing the matter with a slow build progress is still being made.
Johnthesparky
UVA fugitive 4
#33
We knackered a wheel bearing, not sure if we overtightened, undergreased or (because no dust caps) it got grit or swarf in it.
But in doing so we damaged a spindle, we got hold of another pair, cleaned them up and this weekend fitted them,
Not sure how to attach video... but we did a time lapse
https://youtu.be/UbDhjRSI3c0
When you pack a bearing go from one side apply a dab of grease then push it through with a finger repeat as required until grease comes out the other side all around the bearing.
Johnthesparky
UVA fugitive 4
Nearly got the brakes sorted (but I got one of the hoses made with a male instead of female End)
Then bolted the engine in
Starting to look like a real buggy now!
fugglededumm
UVA Fugitive
Go for it👍 Nothing like a little helper 🤛👍👍💋
Johnthesparky
UVA fugitive 4
Not been the weather to get too much done,  but have been chipping away
Bolted the side panels on, using motorcycle fairing fittings
Had got a new steering column machined up, sleeved into a collapsible section then to a pillow block and a detachable boss
Started putting some wiring in, and looking at clutch and throttle cables
Then we got hold of some scruffy slots for the front
Which we've given a polish, and now look like this, they are a long way from perfect.... but look a lot better
Johnthesparky
UVA fugitive 4
We got tyres fitted onto the front slots
Mounted the battery box
Modified the tube that runs under the dash
So we can fit a different speedo, we got an acewell one
And then today we've made an ally dash panel
We've made a bracket for the slave cylinder
And fitted that
Modified the cable pedal to work with a master cylinder
Fitted the front slots, had to get some spacers... but not too worried about the track as the rear is 25mm wider since we fitted the 944 discs anyway
Think that's up to date again
Johnthesparky
UVA fugitive 4
Oh, we've also fitted a fibre flare led
You have been busy, looks good.
Looking good good . Nice one  ;-)up
FireDancer
SWB GP Mark 1
Where did you get the bearing you used for the steering column?
Just visiting from BajaClub.  :D
BajaClub Bash organiser.
Johnthesparky
UVA fugitive 4
Quote from: FireDancer on March 28, 2018, 02:18:04 PM
It's a 20mm pillow block bearing, I think in the end I got it from amazon
We got the steering column made to work with it, the collapsible tube is 22 o/d and 15 I/d, pillow block is 20 and steering wheel boss is 19
So the column is 15 and fits into the collapsible tube, then 22 to match the diameter, then steps down for pillow block (this should also stop the steering column pushing through the bearing in worst case scenario) and then steps down again for the steering wheel boss
Hope that makes some sense
