Toms fugitive 4
Started by Johnthesparky, May 23, 2017, 05:36:42 PM
Johnthesparky
UVA fugitive 4
Hello, it started just over a year ago.
I bought my son a socket set for his 10th birthday, and something to use it on....  which was a 1300 twin port engine
We stripped it right down, and replaced all the bearings, cleaning it up as we went
Painted up the tinware, got it all together
And got it running
About 6 months into the engine build (it's taken just under a year to build the engine as the project progresses at the pace of a 10 year old, and we really only get weekends) I came to be the owner of a fugitive 4
Which we've stripped
Had the frame blasted and painted
Which is about where we are at the minute,  It came with discs at the front (I've also acquired another for spares) so to supplement this I've got some 944 rears to go on.  It's IRS anyway
We've cleaned up the gearbox as well actually
More to follow, but that's a years progress..... so not too soon  :D
Quote from: Johnthesparky on May 23, 2017, 05:36:42 PM
That is just FANTASTIC !!!!!
Shall keep a keen eye on this build   ;-)up ;-)up
Lovin' this thread already! ;-)up ;-)up ;-)up
mad4slalom
Mk1 manta ray
Dont know if "Tom" is you or yr lad, but the time and knowledge and experience you are giving your lad is brilliant and will be with him forever, learning your way around cars tools and engines at his age is of huge benefit. We will all be following this one avidley i'm sure.👍
I love my 3 girls but really makes me wish I had a son, or at least a girl who was interested in cars.  The look on his face is priceless
Big round of applause for both of you
mad4slalom
Mk1 manta ray
I had two daughters ,but one presented us with a gorgeous grandson  so he helps me on the buggy , very very lucky 👍
Johnthesparky
UVA fugitive 4
We got some 944 rear brakes to go on
Had a plan with some citric acid rust removal, and ended up with
Which we primed and then painted with brake enamel (should have got a spray can, but thought Tom might find this easier
Need to clean the back plates and the suspension arms then build them up.   Swapping over to 4x130 hubs as well, because we've got some wheels for the back
John
Johnthesparky
UVA fugitive 4
Went to Stonor Park, got a few bits including a pair of front calipers for £30....  we've got 2 pairs of front calipers but they both need new pistons and seals, these ones were a bit grotty but underneath the pistons and seals looked good, so I talked him down to the £30 and brought them home
We stripped them out, pistons popped with a footpump, and are all good
So we got lucky!!
Once they were stripped, we dropped them in the citric acid bucket and agitated them a bit, but they came up really tidy.  They are obviously pattern parts as the castings are a lot rougher than the other sets, but once painted they'll be fine.
The rears we painted up the other day looked terrible (the Halfords brake enamel wasn't very hard and it had run in places as it's so thin) so they have been stripped again and dunked again.
Then We gave them all a coat of primer and then a mate is going to paint them properly for us!
Johnthesparky
UVA fugitive 4
We removed the back drums... surprisingly for this vehicle, someone has actually spent out on something!
Then cleaned up and primed the IRS arms
Need to get some black paint now!
So then started cleaning up the 944 back plates
I'd take the driveshafts out and give it all a thorough clean, inspection and then service, just for peace of mind.
Johnthesparky
UVA fugitive 4
Yeah, we will.... just at the mo we don't seem to have spline tools (think the garage pixies have stolen them!)
 will be able to strip and clean the inner cv joints, note how they come apart because they only assemble one way correctly and work freely through out the angular range.
Johnthesparky
UVA fugitive 4
We've got a second set of arms which we will get shotblasted later and then we can build them up to swap over at a later date (a few years down the road)
The plan is to get it on the road in about a years time (hopefully) and do a bit of a shakedown in it, then pull it apart for powder coating and sorting the paint etc.
The grease in these ones is a bit like toffee, so will clean them out and have a good look at them when the pixies have finished with the tools  :)
Leebow
Sidewinder(the Kermit)
Looking good mate can't wait to see your progress 😀👍
fugglededumm
UVA Fugitive
Nice. You have the one with the sensible head clearance! Going to have to modify mine or get a few vertebrae removed...
Do you have a close up of how the front mudguard stays are mounted to the backing plate please. Just about to fabricate something and looking for existing ideas.
