Mahoosive Clear Out, Long List of parts, all sorts for sale
Started by Mikeohope, June 07, 2015, 01:46:30 PM
Mikeohope
MAHOOSIVE CLEAR OUT GOING ON..
Hi all
I'm having a major clear out of bits and pieces left over from two buggy strip downs and so far one build up. I've collected a fair bit of stuff over the last 3 or 4 years
There's a lot of it so this is a big list, hope this is OK..
I've listed everything with what I think is a fair price but no sensible offer will be refused..Prices don't included postage and cash on collection (from West London) preferred. I travel around a bit for work at times so could maybe meet people elsewhere at a convenient time..
If anyone wants to uses paypal its fine but will need to be as a gift or price adjusted to allow for fees. I could post most items with a budget courier like Hermes it won't be adding much to the cost.
Thanks for looking and here goes
Engine Parts
D Code Engine Case, may need a bore £75.00
Crankshaft that came out of the above engine case £25.00
Camshaft from the above £25.00
Conrods from the above £30.00
Pushrods and Tubes £20.00
Or all of the above as a job lot for £150.00
Twin Port Oil Cooler £30.00
200mm Flywheel £25.00
Sump bottom plate w/o drain plug £10
Oil filler and breather tube £10.00
Sump bottom plate with drain plug £10
Bottom Pulley £10.00
Or everything above including the first job lot for £225.00
Fuel System
A pair of Weber ITC 34 Carbs, in used condition and will need a clean/service £135.00
A set of CB Offset Manifolds to suit ICT 34 (or Empi EPC), these are brand new, not used, drilled and tapped for balance tube  £70 .00
Pair of single port manifolds to suite ICT 34 (or Empi EPC), these are used, drilled and tapped for a balance tube £25
Pancake Airfilter, rusty £5
Fuel Regulator with connectors £10 (leaking though, probably needs new gasket..
Two Hex Bars for twin carb linkages, one has side arms for fixing to Weber ICT £25.00 for both
Clutch Parts
Brand New 200mm Clutch Kit to suit early release arm, includes pressure plate, friction disc and bearing but not springs £40.00
A used 200mm Clutch pressure plate and friction disc, less than 500 miles in total £30.00
Early Style Clutch Release Arm £10.00
Tinware and associated bits
Heres a used black fanshroud that has been airbrushed. Has heater tubes but there are also some chrome stoppers. I also have the alternator backing plate £40
Heres an older style fan shroud with the flatter top and heater tubes painted in silver but could do with a tart up. No alternator plate with this one £25.00
Pair of painted rocker covers and retainers £25
Pair of chrome rocker covers and retainers £25
Some chrome cylinder top tins, should polish up nicely
Some chrome cylinder top tins painted silver £25.00
Some under cylinder cooling plates £15.00
A brand new front engine tin, damaged in transit by GSF but didn't use it anyway, couldn't make it fit. I bent it back in to shape £10.00
Fan Cover (no fixings) £5.00
Bottom Pulley Tin £5.00
Ignition
Distributors
I have 3 Original SVDA JFU4 Distributors. They have all come from running engines £20 each..
Coil, Make unknown, working £10.00
Bosh Blue Coil, working £15.00
Bosch Regulator (Used) £25
MGB Steering Column with Steering Wheel, still has keys in the ignition and all wiring/plugs £35.00
A set of NGK HT Leads, not sure what fitment £5
Miscellaneous
Beetle Starter Motor (not believe to work) £10.00
Beetle Indicators £10.00
Pair Front Lamps £15.00
Also have the flowing but no pics yet....
Pair of wolfrace slot alloys 4 * 130 pcd, 15 *7J   £50.00
pics to follow
Pair of wide 5 rear drums £40.00
pics to follow
I also have an AB Code Gearbox £150
Pics to follow
Front disc set up  £125
Pics to follow
crowey
I'm,  interested in the front disc bakes can you give me more details please.  ;-)up
Living the dream
Twitch247
Mikeohope
Mikeohope
Quote from: crowey on June 07, 2015, 02:35:27 PM
I will need to dig them out of the garage loft and take some pics. There are discs, calipers and arms.. Will need a clean up obviously..
Mikeohope
Soooo tempted to go retro with the sp manifolds but I'd need heads, tins and studs to make them work... ::)...
Mikeohope
New early style clutch sold
Used late clutch sold
Clutch release arm sold
Hex bars sold
Mikeohope
sawmilljim
loads of bits, big ideas and nothing that works
Could I take the slotmags for my mate Andy please Mike?
Would you be willing to courier them or do I need to arrange collection?
Cheers
The older I get, the better I was.
Mikeohope
sawmilljim
Quote from: Mikeohope on June 08, 2015, 08:46:22 PM
Jim, where is your mate based?
I'm down in South Devon, Andy is on the Isle of White.
My bro-in-law comes up to Thames Ditton and SE London every couple weeks
We're all meeting up at Bristol Volksfest in a couple weeks.
Sure we can figure something out  ;-)up
Mikeohope
I'm in Dartford Kent, most days so se London is doable.
sawmilljim
Quote from: Mikeohope on June 08, 2015, 09:40:28 PM
Could you message me a contact number Mike?  I'll pass it on to Andy.
Cheers
