VoO DoO BuGGy !
Started by toosh, February 09, 2014, 05:56:48 PM
toosh
VoO DoO -The ultimate predator !
couple of snaps from the weekend at vw festival .....  ;-)up
and then the was this........
it's gotta roll around my head, before it rolls on the street
toosh
had a mooch around the stalls at vw festival & happened upon an mdf fret panel .... vee-dub .... for the bargain price of a £5
i bought it with the intention of  mounting it into the rear back board.
here it is
i removed the trim from the board and laid it out to mock up how i wanted it
had to work out where to cut the strips i'd already made before.
so i cut them to suit, then fixed them back into position...... ready for glue.
i always put the carpet underneath the board, so i get an outline of where i need to spray next.
flip it over.
then start working the carpet into the recesses.
then popped it back into the buggy.
JOB DONE !
very pleased with my £5 purchase.
toosh
toosh
ventured down to edition38 with my buddy's from ROUTE 32 .... we had a very good time & 3 members picked up trophies
base camp ROUTE !
early doors in the Que
had an opportunity to go up on the stage  ;-)up
i love this shot
Manxrod
Myers Manx. MK1GP swb
Cool photos ;-)up
make it if you can.
toosh
new engine looming on the horizon ..........
this is what i have bought so far
full flowed engine case
CB performance 4140 steel forged crankshaft
SCAT 8mm c/moly head stud kit
1776 B & P's
straight cut cam gear
ENGLE 110 camshaft
CB performance 044 heads 90.5/92mm 40x35.3 single spring
CSP rocker covers
bolt up rockers with swivel feet
SCAT/manton c/moly pushrods
SCAT lube a lobe followers
EMPI welded fan
6 kilo forged flywheel 200mm
KENNEDY stage 1 pressure plate
metal woven clutch
twin 40 IDF WEBER carbs
CSP manifolds 40mm
CSP bell crank linkage
Facet fuel pump
Malpassi filter
EMPI merged bobcat exhaust 1.5"
PP saw blade pulley & dress up kit
new chrome tinware
bought a replacement tank from flatlands too.
that should keep me VeRy busy over winter !
maxyray
Nice buggy mate. What size rear wheels and tires do you have?
toosh
Quote from: maxyray on November 10, 2014, 01:15:06 PM
cheers dude  ;) .... rears are 17" .... 255/50/17  ;-)up
maxyray
Quote from: toosh on November 10, 2014, 06:27:45 PM
Thanks  ;-)up
toosh
the time has come to strip voodoo down & put stuff right.
then the bare bones was transported to the spray shop.
many areas required quite a bit of attention
the spray shop in action
toosh
another bit done ......  ;D
Wow - they look good   ;-)up
Merscury
Quote from: Dave DND on December 20, 2014, 08:36:39 AM
That was a bit of an understatement Dave, they look gorgeous.
Have fun. Be lucky
BEELZEDUB
Vulture???????
yes those seat do look grand, is your buggy now just Black?
toosh
Quote from: BEELZEDUB on December 25, 2014, 01:49:01 PM
JUST BLACK ?????????????????????????????? ........................... no .... it's now .... phantom black pearl
