sandrail build
Started by 93fxdl, October 17, 2014, 07:45:11 PM
PhillipM
Comp Safari Rail
Quote from: 93fxdl on November 15, 2021, 07:29:29 PM
Over the next few days, hope to strip the rack and remove all the hydraulics, might even be able to reduce the width of it
Ttfn Glenn
Don't forget to weld the shuttle solid or you'll have loads of play just off centre.
93fxdl
sand rail and manta ray
Quote from: PhillipM on November 20, 2021, 12:18:32 AM
Ttfn Glenn
That's part of the plan, will give me an excuse to play with my new tig welder.
Ttfn Glenn
93fxdl
Little bit more done yesterday, welded and started rebuilding the steering rack, then finished lowering the rear suspension, also fitted new rear flexi hoses to the brake lines ready for when the new shoes and cylinders arrive
No progress today, got a 200 mile road trip to bring back a couple of gs550 Suzuki parts bikes
Ttfn Glenn
93fxdl
Few more bits done to Sandra , finished the brake lines, welded a filler onto the tank, hopefully tomorrow will get the brakes adjusted and bled, make a block off for the fuel gauge hole, and get the front suspension finished
Ttfn Glenn
bajaowa
Where's the tank going to fit? I'm assuming the steering rack is taking up it's space.
93fxdl
Quote from: bajaowa on December 04, 2021, 12:41:12 AM
Tank is behind the seats, over the gearbox.
Final placement of the rack will depend on getting the geometry right
Ttfn Glenn
93fxdl
A little bit more progress with the rail, lights mocked up ready for wiring,  new fuel lines and pump fitted, and tha cage roof is all cut ready to be welded back on with some space for human beings to fit inside,  but currently looks like I have a speedster sandrail
Ttfn Glenn
Leebow
Sidewinder(the Kermit)
Nice looking rail,is that a jeans beetle I see in the back ground 😀👍
93fxdl
Quote from: Leebow on December 28, 2021, 10:19:31 PM
Yes it is a jeans,  waiting for its turn to be worked on.
The rail is getting built as a Jeans rail.  Tunis yellow paint with black details, jeans decals on the side, and possibly denim seat covers
Ttfn Glenn
Leebow
Leebow
That's my jeans that I'm planning on doing this next year needs abit of welding and painting 😀👍
bajaowa
A well trained eye young Jedi.  ;-)up
93fxdl
Got a little more done to my experimental rack conversion, a quick cobble together of some box section,  to test out the idea
Ttfn Glenn
93fxdl
The sandrail has taken a slight step back, now trying to focus on my manta ray,
Will need to get it running again,  give it a fresh coat of paint, total rewire, have some new headlights for it
Dont worry too much about the sandrail, that also has been getting some extras
Noisy exhaust
Engine cage
Can see lots of painting in my future,
The manta body, sandrail engine cage and a couple of motorcycle fuel tanks
Ttfn Glenn
bajaowa
2 more for team yellow.  :)
