Start of wifeys buggy - Manx
Started by Speedy, December 10, 2013, 10:16:04 PM
Speedy
Manx
Hi Hunter
Tyres are 255 60 15 rear on 9" rims 195 60 15 front on 6" rims  ;-)up
Work hard : play harder
Speedy
Manx
Couldn't help but mock it up today wife's pleased as punch 🤛
Speedy, looks fab. Is that a mini in the background  ;-)up
Speedy
Manx
Hi Pepsi
The car in the background is my rear wheel drive 300bhp Nissan Micra tarmac rally car I came 2nd in the National tarmac championship in 2004
Built the car from scratch suspension home built shell home built all built in my garage beat so many world cars.
Looks amazing. So much respect for those of you who can build these things from nothing.
No wonder the buggy is looking so good  ;-)up
Manxrod
Myers Manx. MK1GP swb
Looking good  ;-)up
make it if you can.
JonFuller
Captain Corvair
Do your inertia reel units have the adjustment for angle, ie, setting them at a non vertical position?  I assume they'll need to 'lean backwards' to align with the upper shoulder pulley mount.
Jon
Speedy
Manx
Seat belt reels have come out of a smart car same as the seats they are inclined to correspond with the hoop, tried them inclined and they pull out okay and retract they also lock when snatched. Mounted them to bracket welded into the floor as I felt this would be stronger, apart from the roll hoop mounting they mount the same as in a smart car. I also intend to attach the upper roll hoop mount into the body shell back down to the shock mount externally so as it's hidden but still very strong
JonFuller
Captain Corvair
Speedy
Manx
Vw pedals look so bland so I thought I would start sprucing them up a bit. 8)
Speedy
Manx
So got to the point where I'm bolting the body to chassis and I noticed a while ago that the body really doesn't touch the chassis except at the very front and the rear, there is a good 8-10mm gap, I think this is probably due to the fact that the body was made in 2014 and never got put on the chassis properly until this year. So I have power planed some nylon strip into shape then I can tighten body down nice and tight. Anyone else had this issue with a Manx.
Yes   Manx particularly badly misshapen and out of symetric synch either side.  It`s normal for all body castings to change shape dramatically. Try fitting a body say in summer. Take it off again in winter to do work and try putting it back in place. Nothing lines up. "Glass fibre" structures continue to cure for years.   In essence they fit where they touch and they barely touch ;-)up ;-)up
No need for spacers, just use a couple of longer bolts with big washers either side to pull the body and floor together the fit proper bolts. Standard VW floorpan gasket will work best.
#149
The body fitting anywhere near correctly is a bonus, blocks of wood and jacks are the usual tools to get bodies aligned so bolts can be fitted.
