I need a few bits!
Started by dseered, June 11, 2019, 05:55:10 PM
dseered
Now the buggy tub is with me I am going to start properly thinking about the build, so need loads of stuff - this project is going to involve my 7 year old as much as possible and keeping the theme of climate change (loosely) we want to 'up-cycle' as much as possible.
This is not exhaustive but will give me a start - at this stage aiming to get it on the road ASAP - trick bits will come in time.
Essentially what I need is a '64 beetle as that is the chassis I have and in the spirit of buggy - most parts would come from donor.
Front end - Steering box / column / tie bars and all that jazz - will likely go new with braking / suspension but anything goes that serviceable.
Back end: Engine, V5 lists it as a 1300 but open to most things, Prowler buggy has a cut out back end so ideally big and sexy with massive carbs, to get on the road though, most things go.
Interior: there is none but some period Beetle seats would go down a treat!
Windscreen
Silly things that people might have lying around - gear stick, fuel tank, fuel pump, wiper set up (prowler uses original beetle wiper mech etc), seatbelt / harness, little front indicators.
If you have stuff that might be useful please do let me know!
Ideally North West so I can collect but if its post-able then all good, I am based in Kendal.
There is potential that I will be travelling to Brighton for a funeral in the next couple of weeks as well so that might open things up.
1964 you need a king and link pin front axle and a short shaft 1200 gear box a complete 64 as a donor will be harder to find but would come ith another pan and V5.
dseered
Quote from: snoopy on June 11, 2019, 07:42:37 PM
I have 'most' of the front end, beam and king and link pins, need tie rods and steering stuff - have matched gearbox (I think).
Roadrunner
FF LWB
I would reconsider the reuse of an old tank.  Unfortunately the likelihood of leaks on an old one is high and that's not good for the environment
Doon SWB No.1 & No.2
Also a rebuild or serviced original steering box is far superor to the crap oriental replacements you can buy these days.
Flags on here knows a thing or 5 about rebuilding steering boxes.
Hormone
Nice to meet you and Freddie (apologies if that is not how to spell his name) at Pete's on Saturday.
I now think I have more work than I thought to put my buggy properly on the road so the race is on Woody  ;-)up
"One life, live it to the full"
