Indicators
Started by Jimmy T, May 15, 2016, 08:09:35 PM
Jimmy T
White FF LWB
I put my indicators on today in the only place that i am happy with them.
The angle is a bit odd but i don't see anything in MOT inspections that would be an issue. Just wanted to run it by you guys as a 2nd opinion. They look fine from the front as you can see..
But the actual angle from above is as such:
Raw knuckles and sore knees
As long as it can be seen from the front and side without obstruction it should be fine
Can you make a wedge to straighten them up?
Thats exactly how the indicators are on mine, and never had any issues with them   ;-)up
There are 'rules' relating to cars firs used after some time in 1986.  If you are able to keep the original details then I guess they don't apply, but it might be worth checking what you have against these anyway.
The main points appear to be sections 2 & 3 of the attached.  Section 2 - position, as in how far in from the edge of the vehicle etc.  Section 3 - Angle of visibility.  This might be an issue with the lamps pointing inwards a touch.
There's a diagram at the bottom of the page on the link to explain the angles.
http://www.legislation.gov.uk/uksi/1989/1796/schedule/7/made
Are you going SVA/IVA ?   ???
Quote from: Roadrunner on May 16, 2016, 11:04:22 AM
Quote from: Dave DND on May 16, 2016, 08:36:33 AM
It's a LWB FF Dave, he should be fine without one
In that case, wouldn`t worry about them   ;)
