Windscreen angle
Started by parmaynu, December 06, 2015, 06:51:53 PM
parmaynu
Nuffin
Does anyone know the angle a standard manx screen is mounted?
Old Skool Parts Shop
oldskoolpartsshop.com
HUDGE BUGGY
GP Mk2 Super Buggy LWB
Think your going to need a protractor thingy and a Manx David on that one ;-)up
Same as the angle where the bonnet meets the dash, give or take.
Roll bar should be at approx the same height and angle.
parmaynu
Nuffin
That's the one.So what's that angle from vertical then?
Quote from: parmaynu on December 06, 2015, 09:32:12 PM
That would alter a bit depending on buggy stance and how nose down arse up it is, best set the angle that you think looks best or match the roll bar if fitted. Many bonnets have a moulding to put the screen up against so the angle is preset.
parmaynu
Nuffin
Fair point. So what is the angle of a standard Manx roll bar measured from the mounting flange of the body?
Quote from: parmaynu on December 06, 2015, 09:53:25 PM
Lol...same angle as the screen... TBH I mocked mine up and took hours looking at them and adjusting slightly before finally mounting them.
parmaynu
Nuffin
#8
Yeah it's the same angle but if you use the mounting flange you have a working level to use. Would you mind putting an angle finder on your David? It's to help with my monocoque drawings
Thing is with buggies being mostly home builds there is no standard just loads of individual ideas on what looks best,
parmaynu
Nuffin
That's is very true. I am just looking for a close angle to base my monocoque drawings/plans on.
Sorry but I haven't got an angle finder.
parmaynu
Nuffin
Folding protractor?
Smart phone?  iPhones have a spirit level/angle finder in the Compass app - swipe left.
Quote from: Roadrunner on December 07, 2015, 01:11:34 PM
That will still not take into account the rake of the floorpan
How about put a set square on the mounting plate and measure the right angle triangle it makes with the bar, then some fairly simple maths gives you the exact angle
