Headlamp switch wiring
Started by mad4slalom, December 05, 2015, 12:44:30 AM
mad4slalom
Mk1 manta ray
Hi, I have a beetle headlight switch terminals I have are 56, 57, 58, 58b , x and 30.  Any idea where these are wired to. Thank you. ;-)up
#1
Look on manxmaniac.co.uk and type wiring diagram in the search box, Peters site is where you can spend hours the cleaned up version is at the top of this  forum list as a fixed topic.
Doon SWB No.1 & No.2
I have put together a little diagram that may help.
Remember with main and full beam lighting you need the correct size wires to avoid any melting.
mad4slalom
Mk1 manta ray
Thanks chad , that is a great diagram as shows it all together, with the wire sizes to follow too ! Thank you again, ... Off to  the shed now !,
