Manta ray lights
Started by mad4slalom, September 16, 2015, 09:21:37 PM
mad4slalom
Mk1 manta ray
Thanks for that guys, love your led side lights hunter , are they separate ones just drilled through the arch rim? Also , your indicators, what are they from and are they available to buy ? Thanks
Hunter
SDBC Moderator
CTR
Hazel
mk1 GP
Quote from: Hugh on September 17, 2015, 09:51:44 AM
After:
Oh how I love how the sun makes the paint look bright and fresh and airbrushes away the cracks, fading and patchy yellows !
Looking good, where did you get those headlights from?
These are what I call 'Hunter Headlights' because he kindly steered me to them.  See post
http://www.beachbuggy.info/index.php/topic,6716.msg69694.html#msg69694
which had other tips including small tractor lights.
But these 'Hunters' come from America:
http://furoreproducts.co.uk/6-projector-headlights
They are American specification dip which and the main beam is cut down by a shutter for dip. They are legal in the UK. A bit pricey but solved my tyre rubbing on underside of body issues...
Hazel
mk1 GP
Perfect, thanks for the links Hugh  ;-)up
mad4slalom
Mk1 manta ray
Got a phone call today from Jim at absolute Vw, really helpful chap who knows his buggies. Steered me to a supplier of the correct 5.75 " headlamps . Exchanged pictures of buggies and explained a lot about my mk .1 manta ray. Am hoping he can supply me with a set of side pods. Also , when I ordered the headlamps  I also ordered the two folding aero screens a la early Morgan's and the like are fitted with, am going to see if these will work on the manta ray as it has a heavy tubular roll bar in place of a windscreen frame. Will try to get some pics up when they are fitted.
paul
ctr
My CTR has essentially the same headlight bowls as a mk1 Manta Ray.I mounted 5 3/4in headlight units (with built in side lights from S.V.C)  slightly forward in the bowl with indicators above.
