Water leak!
Started by pepsi81, July 03, 2015, 07:03:46 PM
As a rule I don't leave the buggy out in the rain. However got caught out a work, managed to get a cover on(no roof, just a bikini), but not brfore a fair bit of rain got in. Move onto two days later. Noticed water dripping fromthe rubber bung just in front of the rear suspension horns. Can only imagine rain has seeped fromthe floor into the main tunnel . Never seem this before. Anyone else ?
Paul
And there speaketh a fair weather driver   ::)
I carry a bucket in mine for bailing out when it gets over my ankles   ;D
chrisbarker
lwb gt
sounds like aircon to me ;-)up
the arc built by Amateurs,the titanic built by professionals nuff said
 ;D ;D ;D ;D
Should have seen that coming.
GBHgpJON
GP MK1 Superbuggy
After a good dunking, said bung will drip for days.....you will notice the bung has a split in the end, that's to let the water out, but not back in when fording rivers......
Thanks,
Knew id get a sensible answer eventually. So the fairies didn't fit aircon  ;D
Worth looking at the very front of the tunnel, there is a large hole there facing forward, would be behind the front bumper on a beetle, on a buggy it is completely exposed so worth making sure there is a cover fitted over it.
(at least there is on mine)
Yes Doon, the cover is in place, just wondering how so much water seems to have got in when there wasn't that much in the foot wells  :o0
Lots of ways in, front cover needs a seal (mastic will do), Inspection cover inside at the back, round handbrake and gear stick if boots not fitted
Good squirt of Waxoyl once you have got it dry
Hunter
SDBC Moderator
CTR
Quote from: Doon L001 on July 04, 2015, 03:49:08 PM
Don't forget the holes where the clutch/brake/accelerator enter and exit if the water has built up because of the rake and the seals aren't good another access point..
H
Started with a LWB mk1 RAT
Now running SWB CTR
horsenut12
gp mk 1
A good quality bilge pump works if all else fails , there she blows ;D
stormin 'thru
