lwb ff windscreen
Started by Goldfish, May 09, 2015, 07:50:06 PM
Goldfish
FF LWB and a 1974 jeans beetle.
Possibly a silly question but I don't have a clue.... where do I get a windscreen and frame for a lwb ff buggy?
chrisbarker
lwb gt
i think that buggypete on here does them if not then try chad
Measurethe width of the bonnet where it fits, there are/were some on e bay but buggypete may have some.  Once you have the width you can approach buggy suppliers.
buggypete
mk1 and 2 are same mk3 are differant,custom made
BuggySteve
Manxter 2+2 Dualsport
Roadrunner fitted a Manx style one to his I believe  ;-)up
Manxter Dualsport
I did indeed, but had to mount it backwards because of the lip in the bonnet.
You have to loosen the screws off on the side of the screen to get arm around the sides of the bonnet, but all good.
BuggySteve
I have an original mk3 windscreen I will need to look into getting some made. The profile is definately different to Manx style and GP style
Manxter Dualsport
ffnick
swb ff
hi all i fitted a  flatlans manx /us screen to mine the right way round , it was a right pain in the arse but can be done ,the legs are  bent perpindicular to each other and the ff ones taper out at the bottom following the edge line of the original screen   and so does the groove in the bonnet , to get over that i put a lorry strap around the base of the screen  {with glass still in } and then used a bottle jack and a bit of scaffold tube to bend them back out to the correct angle pretty crude and nerve rackin to do to a new screen ,but got it done then just had to remove the bottom 6 inhes or so of hood rail were it meets the bonnet lip  with the grinder  and a round file to radius the end of the cut  to avoid any cracking from hoods/people pullin it back simples lol
nick
Got a GP2 with an integrated screen. Other 5han drilling into the fibreglass has anyone got any other tips.
Paul
