Shaggy's Californian buggy
Started by Shaggy, March 07, 2015, 12:49:32 PM
I`ve seen those Marine hinges on boats down here - very good quality   ;-)up
They are very heavy. I was surprised by the weight and the quality didn't disappoint.
I ordered the bits Friday afternoon and they arrived first thing Saturday morning.
www.jclarkemarine.com
During our annual RMCH and Tatton tour I had a bit of a problem with my top bearing on my column.
It had come adrift and caused the column to float about in the guide tube and short out the horn.
Patched it up with the help of Dave Dream and his tool box and gaff a tape.
So today I thought I'd fix it as it had moved again and was shorting out.
Removed the steering wheel and the spacer was sat floating on the column. ::)
Next remove the circlip stop collar.
URL=http://s617.photobucket.com/user/shaggy1966/media/Facebook/buggy/DSC_0019_zpsi8pj61xw.jpg.html][/URL]
Undo the pinch bolt that holds the switchgear to the column.
Then slide off switchgear.
Slide the new spacer down the column
Till the curved flange is seated on the steering lock plate.
Refit your switchgear and resecure to the column.
Refitted the steering wheel. No more wobbles and shorts for the horn.
Any of the midland crew able to lend a hand taking my buggy apart on Sunday 27th November would be much appreciated, need to cut bolts off for chassis and body separation, floorpan to paint, and a few other odds and sods to do if possible.
After finding a bit of a leak in the body gasket when driving in wet weather, I decided it's time I fixed it.
So I started taking it to bits. It's not been apart in 28 years since I first bolted it up.
Needless to say I'm struggling to get the body bolts out.  :'(
I've carried on disconnecting wiring, fuel lines and brake hoses. (How has this not leaked brake fluid every where I have no idea)
As for my fuel tank that seems ok other than the pipe out the tank snapping off with the hose as I undone the clamp.  >:(
Any way, here's a few pics for you all to look at. Bare in mind I built this on a budget of string and bubble gum wrappers and anything I could scrounge in a breakers yard. ;D ;D
Buggy pics
Sorry but I will have to give the body lift a miss until my back has decided to stop hurting, you could use trestles and beams across them to raise the body a end at a time then roll the pan out from under it if you are stuck by youself.
Allan
Shaggy, I can call around Sunday for an hour or two, would be about half 11 if that's any good to you?
Badger
GP Ranchero
my bodys been on and off today, will be on and off tmorra,,,,
hell i may aswell do another on sunday  ;-)(-;
how many coffee breaks do i get  ;-)up
You all are most welcome plenty coffee tea and poss bacon sarnies for any willing volunteers
Thank you to Allan, Vanessa, Lawson, Rich and David, also a thanks to Amy's (Scrappy) boyfriend Glen who helped me strip it out over the last couple of days.
Will post some pics tomorrow morning.
Had a few helpers on Sunday morning to help with my body lift
Had to cut every body bolt off with the grinder. After 28 years they were a tad rusty.
Ended up cutting the brake lines to the master cylinder from the reservoir and the bolts for the steering column.
All together ....lift..... oh crap, missed a fuel line.
Body finally off
Bare looking. Found a few small bits to fix on the right rear corner. Bit of welding. Clean up the chassis and a repaint.
Hopefully a bit of video for you to see.
apmaman
1962 Volksrod
Great work team!
So whats the plan for the motorised skateboard now  ;D ;D
Just some small repairs and servicing of some parts with a repaint of the chassis, new body gasket and hopefully new strengthening bars in the chassis to help reduce the twisting when cornering.
Plus fix any thing else I happen to break.  ;D ;D
Zip Buggy
FF Buggy LWB
Proper community this one  ;-)up
Doon SWB No.1 & No.2
Sorry I couldn't get there this Sunday.
Did try but couldn't quite shift things around enough, although it looks like you had plenty of help anyway.
Give me a shout about the wiring though buddy.
