Fuel tank vent
Started by Myfirstbuggy, April 09, 2024, 09:57:53 PM
Quote from: Myfirstbuggy on April 14, 2024, 09:07:49 PM
I'm guessing that the standard VW sender unit is next to useless due to the angle of the tank ?
It's OK, it's a rough guide. You can get gadgets to recalibrate. Mine reads 3/4 when full, 1/2 is pretty much spot-on, I fill up when it gets below 1/4.
I carry a can but have never needed it in 12 years so it works for me
You can calibrate it by be ding the arm so 1gallon/5 litres is at the top of the red area so you know fuel is low.
bulliporker
bugle
is the mini  filler neck  totally different to the vw  one,   will the  mini cap not fit onto the vw   neck anyone got a picture of the mg  midget neck   as got the flip top but  no locking cap underneath   tried numerous caps  but all to tall so using a vw t3 locking cap at present
Myfirstbuggy
None ye
Quote from: snoopy on April 13, 2024, 03:22:54 PM
We have a vented locking cap with a 50 mm pipe from CBS
Can I ask what sort of black trim did you use on the bonnet edge ? cheers Jon
myfirsybuggy
It is dark green wing bead with the flat cut down to suit the depth.
bulliporker
bugle
manxdavid do you have a picture  of the filler  neck of the mg midget or mini   showing the difference   between this and the early beetle one
Quote from: bulliporker on April 16, 2024, 03:10:04 PM
I just Googled an MGB one, same cap. Most BMC/BL cars had the same cap.
Doon L040
Doon LWB
I modified a new standard tank by blocking off the original filler pipe and adding a new one to the top so I could have a Le Man's style chrome cap. The air vent on the O/S of the tank went via a one way valve allowing the tank to breath but not leak fuel. Hope that helps. 😎👍
Myfirstbuggy
None ye
Quote from: Doon L040 on April 17, 2024, 11:04:26 AM
Very neat work there !
myfirsybuggy
