GP LDV - The rise of Phoenix
Started by IDA, June 27, 2018, 08:13:11 AM
IDA
Mk2 Rat and LDV
Did a part strip and its had new Mexico heads  ::) In the past One of the valve guides looks bad so has a stuck valve to top it off someone has had a go at the gland nut bleugh.. All I need is a good case but not looking good!! Heads may live on if they are not to bad as i will re build them with Bigger seats and valves as there have small valves from stock..
