GP LDV - The rise of Phoenix
Started by IDA, June 27, 2018, 08:13:11 AM
IDA
Mk2 Rat and LDV
Top welded in and brake lines in
Bottom I got see as I may plate it but think I can do better! I will gusset the forks why I'm at it to help stop fork flex
can you v cut the sides of the bottom plate so it will bend up level with the rear plate then weld the join and the closed v cut, you could put a bridge plate on top of the rear before bending the tunnel bottom up for more strength.
IDA
Mk2 Rat and LDV
Quote from: snoopy on September 26, 2020, 08:25:38 PM
That is the way I was thinking to give it a clean look and to save any  >:( at mot time But not a lot of room to get a cutter to cut it will see today If I can ..still got 2 fuel lines to fit as well
IDA
Mk2 Rat and LDV
Will clean it up and weld it in tomorrow I did a lot of pipe work in the tunnel in the bit of time I had today..
IDA
Mk2 Rat and LDV
More welds to clean
IDA
Mk2 Rat and LDV
Well I was looking at some old pic of the buggy with 10" rims and 295/50/15 boots and the tyres sit way out and to get the wheels deep up in the body as I would like. the wheels need? to go back 2"!!... So as I can add track but not take it away faster... I"m going to take 2" each side more out For a fall 10" narrowed rear  :D I will put the body back on and move the wheels as needed so I can cut the arms as needed
Wouldn`t it have be easier to widen the bodywork?   ???
JonFuller
Captain Corvair
The pics of that chassis you're welding (with blue rear forks) appears to have narrowed rear torsion tubes already. (you can see the weld/rusty join)
Jon
IDA
Mk2 Rat and LDV
Quote from: Dave DND on September 30, 2020, 06:03:53 PM
Yes it would but  ;D I have no drive and to get it in and out my garden its a panel fence job. And they look  :-X if widen
IDA
Mk2 Rat and LDV
Quote from: JonFuller on September 30, 2020, 06:51:30 PM
Jon
I know it has. as I did it but only a total of 6"
IDA
Mk2 Rat and LDV
I'm out for a clean? safe! look no wheels out the body line etc. at that I may fiberglass the back lip! Back to stock as it looks  :-[ To recut and weld the tubes is not hard Getting it to ride right is the hard bit!! But air bags will help. . This is a pic of a 9" cut but with T-bars no lift.
IDA
Mk2 Rat and LDV
Pipe work all in..
IDA
Mk2 Rat and LDV
Arm having a dip 12v for 12hrs
Now striped so will go back in for 12hrs
common failure the bump stop rubber mountings rotting off.
IDA
Mk2 Rat and LDV
Quote from: snoopy on October 18, 2020, 05:29:31 PM
Going to flip the arms and cut a lot out and will be making new bump stops
