Wide 5 smoothie needed 15”
Started by Marsdenmoor, April 09, 2019, 02:07:27 PM
Marsdenmoor
One of mine in bad shape when we took tyre off so looking for another. It's going to be blasted and powder coated.
Cheers
Quote from: Roadrunner on April 09, 2019, 02:51:47 PM
What width are you after?  Just Kampers sell new ones.
Made in Italy at a factory that made them back in the 70`s.   I have purchased these and they are fair value for money in my opinion.
Marsdenmoor
Ok was worried about them not being the same each side but if they are the same then I'll take a look. 5" wide for front
Cheers
HUDGE BUGGY
GP Mk2 Super Buggy LWB
Marsdenmoor
Blooming eck HUDGE they are what you call wide!! I've already got some banded steels for the rear (not as wide as those bad boys tho) just looking for a standard 5" wide 15" for the front.
HUDGE BUGGY
Then Just Kampers is the place for you, brand new and you will know that the tyres will seal, bearing in mind most of the braking is done by the front.
ajp
GP MK1
Not sure about the smaller sizes, but i've just had tyres fitted to a new set of 8x15 from JK and 2 places didn't have the larger valves required for the rim...just a heads up in case ;-)up
Marsdenmoor
Yea thanks my tyre place has them.
Keithmanx
Manx
You got a link for the valves? I ended up with tubes....
Cheers  ;-)up
My bad it wasn't eBay
https://www.tyrebaydirect.com/product/tr415-tubeless-valves-32mm-length-snap-in-valves-qty-25/
The link above will work, but what you are looking for anywhere on the web is tr415 valves
They are used on Landrover defenders too
ajp
GP MK1
Tr415 - they're the kiddies! They were also referred to by one fitter as 'taxi valves' - used on black cabs.
Got my tyres fitted in the end at a place that also does commercial vehicles - no problemos.
Keithmanx
Manx
Marsdenmoor
Just picked up a set of 5 smoothies but only need the one so there'll be some for sale if anyone needs any!
