Looking for a T25 CU 2000cc Engine
Started by Dave DND, August 22, 2016, 08:36:31 AM
Got a bit of a bottom end issue on mine, so looking for another engine to play about with.
It must be a Type 25 Aircooled 2000cc CU engine with the flat / rectangular exhaust ports.
If its a good runner, then I`ll use it as a replacement, and if its a dead one, then I`ll use it for a rebuild to replace mine
Anything considered really from Short/Long block to complete turn key lump
Hi Dave, I'm sorry to hear that you have got more problems with your buggy, the bottom ends on these engines are so strong and very rarely give problems. The only thing that usually lets them down is a dropped valve seat  :o Did you tighten the flywheel up properly?
I have got a half re-built CU code 2.0L engine sat in my garage. I got as far as putting the B+P's on it and shimming the flywheel, dizzy drive is in and fan drive is on. £275 if it is any good to you  ;)
Cheers Rob
YES PLEASE  ;-)up ;-)up ;-)up
Consider that one well and truly sold   ;-)up ;-)up
