Chassis No
Started by frenchking, July 05, 2017, 02:41:36 PM
frenchking
GP
Hi,
just put my buggy in for its first  MOT since I bought it and they cannot find Chassis no.
Its not in the usual place on top of the tunnel in front of the inspection plate.
I spoke to the last years MOT station and they could not remember where it was but said it took a long time to find.
Any suggestions of where to look would be most appreciated
Cheers Peter
It should be on top of the tunnel, but often obscured under 50 years of paint
Once you have found it, why not get an aftermarket chassis plate stamped up and attach it somewhere easy to find
Nosebolt
1969 Powerspeed Powerbug
should be on your V5, my MOT guy was fine with that on another project last year
You could get some number stamps and stamp it on to match the V5
Oojamaflip
Californian
Just an idea first beetles used to have a plate just in front of the gear stick check there too if it an early early beetle  ;-)(-;
Kango T top
SWB Girlfriend
Testa
I'm sure on early chassis the number was not stamped. It was only on the riveted on metal plate. Might be wrong but also  if of a certain age kit cars do not require a chassis no.
Quote from: Testa on July 05, 2017, 08:55:19 PM
Defineatly wrong on that one  - All cars MUST have a Chassis number  ;-)up
#7
Chassis numbers aren't required on vehicle first registered before 1st August 1980 for MOT test.
http://www.mot-test.net/mock-test/vehicle-identification-number/
http://www.motester.co.uk/mot-checks/mot-test-of-registration-plates-and-vehicle-identification-number-vin
...or on kit or amateur built vehicles built before 1st Sept 2001 (MOT manual page 6.3).
frenchking
GP
Hi All
many thanks for all your help Buggy booked in for MOT tomorrow accepting use of V5C as proof of VIN
Cheers Peter
Nosebolt
your issue got me thinking so I am printing up a build plate for the powerbug, also done a generic version, luckily I have the kit to print onto ally so this will be a credit size aluminium plate
fugglededumm
UVA Fugitive
I can't find mine on the Fug either. Anyone have any suggestions for a source for making up plates, I asked in our local Timpsons and they wanted £18 which I thought was a bit excessive. I could buy a punch set but I don't want another once every 5 years tool cluttering up the garage!
Got some stamps here could make a plate that you could weld on, cannot remember what size they are but thinking they are small but as long as they are legible it does not matter.
Stamping of vin numbers....  3mm is the current legal minimum height.  Just don`t smash your thumb whilst you are at it.
madmatt
sidewinder
I got some vehicle id plates on eBay,they look the part. Just need stamping in the blank spaces and riveting on.
The more you know,the more you know you don't know
3mm mm for chassis vin .  No reg for id plate.
