Timing strobe and electronic ignition
Started by davydoff, May 18, 2016, 08:41:11 PM
davydoff
LWB RAT
 ;-)up ;-)up ;-)up ;-)up ;-)up
lets order a timing light and see what happens...
Manx2 UK-00-25
Mines as basic as it gets and runs on two batteries inside it....
Its a bit less bright than some of the nice ones  :( and has just one lead to number 1....
Sooo, I time Stell at night!   ;-)up 8) ::)
Peter  ;D
davydoff
LWB RAT
hahah
i dont what to make t any harder for myself..think i'll go for a really bright one :)
Luddite
GP2 SWB / GT LWB
Quote from: davydoff on May 19, 2016, 10:02:09 PM
My pulley has marking on it, its this one
So i guess i'm ok with using these numbers
Check the TDC position when you've fitted the pulley - the numbers on one I had were about 12° out.
FWIW, get one of the strobes with the clamp-on sensor, the intermediate plug cap type can give issues with some types of electronic ignition.
If it ain't broke, fix it 'til it is...
davydoff
LWB RAT
Quote from: Luddite on May 20, 2016, 08:46:42 AM
OK, next question, how do i do that?
i know can take dizzy cap off and see the arm pointing to No1
i don't seem to have a notch in the dizzy (petronics 3)
how can i be sure i get exactly TDC?
I heard that removing a spark plug and checking with a pencil or similar can do this but what am i checking?
cheers
Luddite
GP2 SWB / GT LWB
Plugs out, one rear wheel off the ground, one rocker cover off, vehicle in gear.  Rotate the engine using the wheel until both rockers are loose put pencil in no1 plug hole and feel for the top of the piston, keep turning the engine gently until the pencil is at its furthest out - you'll get a lot of rotation for little or no pencil movement here, so move the engine to the middle of the dead rotation phase.  That will be TDC, you can check your pulley alignment against the pointer or crankcase joint.
Actually, I just thought, there's a much simpler way! The keyway should be at 90° at TDC, looks in about the right place from your photo so no worries.
davydoff
LWB RAT
Krug
And keep the pencil in the centre ..... you dont want the piston grabbing it and bits of pencil led and wood being in your cylinder
Manx2 UK-00-25
QuotePlugs out, one rear wheel off the ground, one rocker cover off, vehicle in gear.  Rotate the engine using the wheel until both rockers are loose put pencil in no1 plug hole and feel for the top of the piston, keep turning the engine gently until the pencil is at its furthest out - you'll get a lot of rotation for little or no pencil movement here, so move the engine to the middle of the dead rotation phase.  That will be TDC, you can check your pulley alignment against the pointer or crankcase joint.
Mmmm  ;-)up I think I prefer the pencil method... Just rotate the engine and mark the pulley with your pencil just when the pencil
stops moving and then mark it again, with the pencil, just when the pencil starts....
TDC will be/is, right in the middle of them  ;-)up
Heaven's, I just love technology, don't you ?  ;-)up  ;D ;D
Hunter
SDBC Moderator
CTR
Quote from: Peter on May 19, 2016, 10:08:13 PM
QuoteSo i guess i'm ok with using these numbers
Yup! I guess you are  ;-)up ..... Go for it Davy  :)
Just do me one favour, once you've fitted the new pulley just check that TDC mark on the pulley is actually TDC.
H
Started with a LWB mk1 RAT
Now running SWB CTR
Using a degree pulley check the tdc marking first by removing number 1 sparkplug and feeling the top of the piston as you gently turn the engine in a rocki ng motion forwards and backwards to find the highest point of travel ( a dial test indicator gauge is the best tool ) but a rod and sensitive hand will do. When piston is at TDC check the tdc sticker lines up with the case join.
I have known stickers to be out of place so your timing will always be wrong.
Hunter got there as I was typing ;-)up
apmaman
1962 Volksrod
If you dont have a helper how'd you get it to stay at 3000rpm to hold gun and rotate dizzy?
Hunter
SDBC Moderator
CTR
Quote from: apmaman on May 21, 2016, 03:19:45 PM
on some carbs you can screw the tick-over adjuster in ........
with an unloaded engine they rev quite easily
Now running SWB CTR
apmaman
1962 Volksrod
 ;D ;D
Never even though of doing that.... Was looking for a suitable stick in the garage!
Hunter
SDBC Moderator
CTR
Quote from: apmaman on May 21, 2016, 04:22:47 PM
;D ;D
or a suitable brick...
Now running SWB CTR
