Cooling fan
Started by pepsi81, December 15, 2014, 07:03:38 PM
Been checking various things while the engine is out. Discovered a 5mm gap between the cooling fan and dog house shroud. >:(
Does this mean Ive a standard fan in the wrong housing. Cooling has never been an issue :-* Worthwhile fitting new while all in bits  :-\
Any thoughts.
Paul
It sounds as if you've got a pre- doghouse fan on a doghouse shroud. I'd get hold of the proper fan before you put it together.
Thanks  David, that's what I'll do. Measured mine, it's 30mm, believe that dog house is 35mm  :)
Paul
