What can I undo/take of the back of chassis ?
Started by djdunkyd, September 27, 2014, 08:48:44 AM
djdunkyd
Fiber Fab Rat Mk 2 LMB
Morning All
I have a question about the back part of my Chassis as to what I can safely take off and undo to to give me access to clean it down ready for painting. I am only doing it buy hand with Hammer-rite. Are their bit that I just should not undo or others I can take out a couple of bolts clean and then put them back ?
Manxrod
Myers Manx. MK1GP swb
You can take the gearbox out with the swing axles as one a simple enough job refer to a work shop manual as the axles have to go back in to the same position as they came out you can mark the position with a cold chisel before you start. Good luck with the refurb. ;-)up
make it if you can.
As said box and shocks are easily removed and refitted just needs the brakes bleeding afterwards.  One observation your clutch outer flexy tube needs to have  more of a bend in it or you will suffer from judder on taking up drive plus one other the joints on the drive shaft boots want to be a 3 or 9 o clock not 12.
