Bits For Sale
Started by Steve, September 08, 2014, 12:27:22 PM
Steve
Street Predator
Selling off some of the stuff that I have bought in the past with some ides in mind, but changed the ides back to stock.
Postage is extra, I will find out the prices if anyone is interested in any of the stuff and then let them know.
I might be a little while posting things out as I have to rely on my wife, as I can not really drive at the moment.
Carbon Look Racing Mirrors.
Brand new in box, never used, comes with mounting screws if needed and adapter plates, Can be bolted straight to the shell without adapter plates.
Cost me £50 + Postage.
Selling £35 + Postage
All photos here
http://s603.photobucket.com/user/negativepitch/library/Mirrors?sort=2&page=1
Brand New in Box.
Carbon Look Steering Wheel with centre horn push and Accessory buttons. (Buttons are Momentary)
Wheel Diameter 14 inches in old money
£12 + Postage
More photos here
http://s603.photobucket.com/user/negativepitch/library/Steering%20wheel?sort=2&page=1
Brand new Sealed in Packet.
EMPI Aluminium Billet Brackets.
Ordered these from Dans Performance Parts in the USA.
They are a single hole mounting on the top. (They are upside down in the photos)
Fits Tube Diameter 1-3/4 inches, in old money.
The bottom photo shows the single type hole mounting brackets in use mounting my breather.
£15 EACH + Postage, They are £25 each (special order only) from just Kampers, or pay USA +shipping
Brand new Aluminium Billet Brackets.
Ordered these from Dans Performance Parts In the USA, They come loose from Dans, not packaged. (you would not belive the amount of brackets I have bought from Dan's for different things  ;D )
They are Two hole mountings. (I have left one of my own screws in each, for ease of identifying thread etc)
Fits Tube Diameter 1-3/4 inches, in old money. ( The left one in the photo is very slightly marked in one place on one side as can be seen)
£16 + postage for the right one.
£14 + for the left one (very slightly marked on one side)
Brand New (loose) never fitted.
Sparco Steering Wheel accessory Buttons and Brackets.
This can be mounted behind (or in front if it fits) of your steering wheel depending on the steering wheel.
It comes in two parts for ease of fitting.
It also comes with a six hole boss adaptor (which I bought separately to go with it) and wiring for the switches. Please read the details on the DemonTweaks link below.
It comes with two red momentary switches, but I also bought and fitted two latching ones as seen fitted in the photos, which I was going to use for my indicators, using detachable from the dash curly cable.
The switches just slide in and out for fitting or changing over.
Brackets
Boss
Latching switches
£15 + Postage
http://www.demon-tweeks.co.uk/motorsport/steering-wheel-bosses-accessories/sparco-steering-wheel-buttons
Please note, the Steering wheel is not for sale, only used for illustration purposes.
I will be having other things for sale (when I get the chance to dig things out), like different sizes of fuel tank roll over valves etc.
Chimp
first dibs on empi brackets with the one hole. I will measure my cage when I get home and let you know. Thanks
Hunter
SDBC Moderator
CTR
Steve Can I please have dibs on the other brackets subject to a measure up when I get home.
Cheers H
Started with a LWB mk1 RAT
Now running SWB CTR
Steve
Street Predator
Chimp , Hunter, no problems  ;)
Hunter
SDBC Moderator
CTR
Quote from: Steve on September 08, 2014, 04:07:09 PM
???  ???  I've never hunted Chimps in my life.....................Honest......... :D
Steve, sorry mate, no good for me I'm afraid. My bar is 2 1/4.
Cheers H
Now running SWB CTR
Steve
Street Predator
Quote from: Hunter on September 08, 2014, 05:33:48 PM
Cheers H
;D
No problem  :)
Chimp
Sorry Steve but wrong size for me too :'(
Steve
Street Predator
Steve
Street Predator
#8
Savage Billet Switches.
Thay are blue light when the switch is pressed or they can be wired for the blue light to stay on all the time.
They can be mounted onto the dash as is, or the the back mounting ring slides off to enable them to be flush mounted onto the dash.
They do not come with the wiring instructions, but these can be found online, or I can email you a photo of one.
These are normally £17.99 new + postage
I would like to get £10 each + 1.99 postage
They were flush mounted onto my dash and then wired up by chad while I was re-doing my dash, but never used as I went back to my old switches, so some of the contacts on the blocks may need to have a rub over, but nothing bad.
If you would like to buy any, could you just say the number which corresponds to each one.  :D
1 A blank momentary switch
2
3
4
5
6
7
This one has no screw on plastic ring to hold the billet parts on, it also does not have a terminal block,
This is £3 + £1.99 postage
8
This is a Mocal Breather and roll over valve.
These are normally £26.00 new. it is brand new and I have never used it as I also bought a larger size.
I would like £12.00 + £1.99 postage.
QuoteMedium flow fuel tank breather valve from Mocal. It has capacity for cars with a moderate fuel consumption rate. This valve fits into the top of the fuel tank itself, a hole needs to be drilled and it is secured internally with a lock nut. Can also be fitted to the removable top plate of a fuel cell if required or sneaked in on a fuel sender unit if space allows. It is straight in-line 6mm male outlet for the breather hose to be pushed on to. Without a breather valve, a fuel tank cannot replace the space left by the reducing fuel and a vacuum tries to form. This makes it hard work for the pump to suck it out and the tank will collapse inwards. These valves allow air in as the fuel is used, yet close off should you roll over or if fuel tries to exit from the valve itself, due to the ball valve which closes when inverted or if pressure is applied, a useful and sensible safety feature.
Precision engineered safety roll over vent valve
Straight in-line vent valve with 7mm barbed male outlet
Aluminium construction with chromed ball valve
2 transparent blue suicide toggle switch's,
£3 for the pair + £1.99 postage
FireDancer
SWB GP Mark 1
Please can I have:
Sparco Steering Wheel accessory Buttons and Brackets. - £15
Mocal Breather and roll over valve. - £12
Let me know a total with postage and I'll send you the money.
I'm in no rush for the parts though.
Just visiting from BajaClub.  :D
BajaClub Bash organiser.
Steve
Street Predator
#10
Quote from: FireDancer on September 10, 2014, 07:20:23 PM
Please can I have:
Cant see the postage being more than £3, I'll  try and get them packed up today, and see if the wife can get them to the post office in the morning, I'll let you know  :)
If they are no good for you send them back and I will refund the money to you  ;-)up
EDIT  ;D
PM me your address
FireDancer
SWB GP Mark 1
PM sent.  ;-)up
Steve
Street Predator
Both pending fitment.
SOLD, Sparco Steering Wheel accessory Buttons and Brackets
SOLD,  Mocal Breather and roll over valve
Wrinkly Ninja
Swiss Buggy
For no reason other than I like them, can I have the toggle switches please?
Will dance for petrol.
Steve
Street Predator
Quote from: Wrinkly Ninja on September 11, 2014, 09:47:22 PM
can you pm me you address  ;)
