Another assortment of things!
Started by Buggybaggy, July 24, 2026, 07:02:16 AM
More bits from my garage I might as well get rid of.
All priced for collection from Leeds, or hump n dump, or meet up at a buggy gathering etc. Postage will be at extra.
Distributor cap (Betu) for a Saab 93 which fits VW distributor and provides side mounted HT cables if you want something a bit different.
£5.00
Inlet manifold. Heat risers are not blocked, although I cannot guarantee they are 100% clear.
£10.00
Gear linkage kit.
£10.00
Cannon exhaust.
Has a few squashed section so probably best for cutting up as donors for something unique, or make good another set with damaged muffler section.
£30.00
VW Polo rear light.  Great if you need one, or want to make a man shed lamp.
Comes with a free mummified spider........I'm sure it'll blow out with an air line, maybe.
£10.00
Split Screen van workshop manual. A bit grubby around the edges!
£10.00
bulliporker
bugle
steve  will have the dizzy cap   can  you give it shaggy and will pick up at tatton park
Quote from: bulliporker on July 24, 2026, 12:41:52 PMsteve  will have the dizzy cap  can  you give it shaggy and will pick up at tatton park
Will do.
SmilesPerGallon
LWB JAS
I would be interested in the t2 manual if you can post it?
They say money can't buy happiness, but I built it instead
Quote from: SmilesPerGallon on July 24, 2026, 06:22:16 PMI would be interested in the t2 manual if you can post it?
I'll find out how much it'll be and let you know.  (I presume you are in tge UK)
SmilesPerGallon
LWB JAS
Quote from: Buggybaggy on July 24, 2026, 07:34:17 PM
yes. I will pm you an address
LUDVIG VON INGLEBERT
I would be interested in the gear linkage if you can post it?
Quote from: LUDVIG VON INGLEBERT on July 25, 2026, 08:11:37 PMI would be interested in the gear linkage if you can post it?
PM me your address and I'll get a price for postage.
If you are UK mainland it will he £3.65 to post the gear linkage.
Steve do you know if the inlet manifold is for a 1300 or a 1600 engine ?
Quote from: Hugh on July 28, 2026, 04:54:28 PMSteve do you know if the inlet manifold is for a 1300 or a 1600 engine ?
It came off my 1600..
Originally carried a Solex PICT34 carb.
Thanks Steve. I'd have been tempted if it was from a 1300.
Deserves a good home at your price.
