Brakes
Started by mancityjeff, June 10, 2025, 07:20:04 PM
mancityjeff
lwb 1971
Hi, I have converted my drum brakes on front to disc but it has made the peddle very soft and a lot of travel to brake, would the master cylinder need an up grade, I have drum on the back, would it be a mix of both systems why it's seems to be not working ok, any advise would be great.
Mancityjeff
PhillipM
Comp Safari Rail
If the pistons are a lot bigger it might need a bigger master cylinder (but in that case you'll have a huge mismatch in front to rear brakes) - definately don't still have air in the system?
One of them mucky ones. Sorry.
mancityjeff
lwb 1971
No have all air out, going to see if I have any adjustment on peddle, thanks
Krug
When I did my buggy had exactly the same.  Fitted some residual pressure valves and sorted it.  https://www.kingfisherkustoms.co.uk/shop/residual-pressure-valve-2lb-suit-disc-brakes/
^^^ WHS ^^^
Residual Pressure Valves are what is needed
My Brake upgrade story may be worth a read?
https://www.beachbuggy.info/index.php/topic,20.msg62087.html#msg62087
Quote from: Krug on June 12, 2025, 04:54:06 PMWhen I did my buggy had exactly the same.  Fitted some residual pressure valves and sorted it.  https://www.kingfisherkustoms.co.uk/shop/residual-pressure-valve-2lb-suit-disc-brakes/
I tried that too. Kingfisher didn't have them in. I got some elsewhere but they had a incorrect thread to attach to the existing fitments..
I ended up doing without. Brakes work fine, once you've pressed the pedal enough.
The problem is that drums are adjustable so don't back off further than the adjuster let's them, discs on the other hand will drift back as gar as they can.
The residual pressure valve keeps enough pressure on them to allow them to back off the disc and then stop.
Potentially dangerous without as after a long run with no braking, eg a motorway, in an emergency you may have to pump the pedal to get brakes.
