Air Intake?
Started by mattfordbristol, August 18, 2021, 05:43:21 PM
mattfordbristol
All,
Daft question, but where is the air intake on this engine?
Is it where the grill is shown?
If pic is that bad, then i will upload a fresh one.
Thanks alot
Matt
Matt
It is indeed the big round chip pan basket at the back   ;-)up
Known as a Type 4 engine
Type 3 and type 4 with the fan mounted on the crankshaft means you can keep going in the event of a fan belt failure as long as there is life in the battery.
If you mean engine cooling air then as answered above.  If you mean air intake for mixing with fuel to make it go 'bang" then that's not on the photo.
IDA
Mk2 Rat and LDV
I'm going to say that engine has a turbo!! And or efi...
bajaowa
Indeed the term normally refers to fuelling. As such your air intake is usually where your air filter starts.
