Top and bottom Ball joints
Started by Paddy, March 21, 2017, 11:36:49 PM
Paddy
RIP - 23/06/2018
GP MKII LWB / LWB Doon
Hi peeps as said top and bottom arms needed for my 72 buggy, i have a set in but they are just way too tight/stiff. They must be new ones or similar so i just want to see whats out there if anyone has a looser set ? or advice.
Paddy
Rest In Peace - You will be Forever in our thoughts . . .
grissley
get some from FIRSTLINE (british manufacturer)they are the only decent ones I have ever bought new.
I fitted 3 sets before I came accross this company  ::)
fugglededumm
UVA Fugitive
... But
1) make sure they are long enough for the arms. I had to un-mount a Firstline one that I pressed in because although supposedly correct the body was 15mm shorter than the one that came out.
2) Make sure you line up the notches fore/aft - if it has them, the FL ones do but some others don't
grissley
you clearly had the wrong ones there then  ;)
fugglededumm
UVA Fugitive
Yep - despite being labelled as the correct ones by major FL dealer...
