Washer for Revolution wheel bolt
Started by Merscury, January 25, 2017, 12:45:14 PM
Merscury
Predator
Long shot but it seems they don't make Revolution wheel bolt washers in this size anymore.  I only need one chrome washer, condition of chrome not important.  size is as follows
outside diameter 27mm, inside diameter 14.3mm, thickness 4mm.  the outer edge of the washer has a slight bevel
Have fun. Be lucky
Big GP
I'll have look but they are like rocking horse poo
Merscury
Predator
Quote from: Dave DND on January 25, 2017, 12:53:43 PM
Have a look in the washers section on the left
http://www.grayston.biz/wheelnutmenu.htm
Already checked out the usual places Dave, it seems all the modern ones are only 24mm outside diameter
Have fun. Be lucky
Merscury
Predator
Quote from: Big GP on January 25, 2017, 12:50:15 PM
Thanks Gary, must admit you were my main hope on this one
Have fun. Be lucky
Doon SWB No.1 & No.2
I may have one or two but need to check.
HUDGE BUGGY
GP Mk2 Super Buggy LWB
I'll have a look tonight Paul, got a few spare washers, whether they are the right ones is another matter. ;)
Got some spare standard flat washers that size but only 2.6 thick I use on my revolutions for the winter if you want some. Even the beetle used a selection of them and the correct washers due to unavailability.
HUDGE BUGGY
Centreline washers are similar ID ok OD 2mm short and incorrect bevel   - sorry mate - good luck with the hunt = just an idea could not a local machine shop/engineering/ fabricator knock up a few in a lathe. ???
Merscury
Predator
Many thanks everyone, I've got one, perfect match, just got to get it rechromed.
Have fun. Be lucky
Thats good , I was going to look tonight, but now I don't have to  ;-)up
