Wires to speedo
Started by Aldo24, September 28, 2016, 08:55:35 PM
Aldo24
Fibre fab rat
The bulb holders for battery light an oil light only have one pole on them on peters wire digram it shows wire from fuse box an from relay should I just run wire to dash an use that or does it need the one from fuse box as shown an join them thanks
Doon SWB No.1 & No.2
Hi Buddy,
Hope this helps. The Oil and Charging lights need a +ve feed to the outer part of the bulb case.
Zip Buggy
FF Buggy LWB
Quote from: Chad on September 28, 2016, 10:03:10 PM
Hi Buddy,
Chad that is a superbly easy to follow diagram. I'm planning a bit of a re-wire this winter. Would you know where I could find a complete full colour diagram for a 74 1300 beetle loom with alternator?
Hi Mark,
That's an extract from one of my own diagrams.
I can supply bespoke diagrams with wires and fuseboards as a re-wiring kit for buggies but I won't now be doing any until after Christmas due to my wife's impending operation which will keep her off her feet for 6 weeks.
I do them in my spare time and after work, and time will be severely lacking until after Christmas now.
All the best
Zip Buggy
FF Buggy LWB
Hi Chad. That's brilliant about the diagrams. I'm in no rush so will get in touch after Xmas; I'm definitely in the market. More importantly best of luck to your wife for her op.
Aldo24
Fibre fab rat
Cheers Chad I'll see what happens thanks hope all goes well 4 you an ya good lady
