I want to change to twin stalks
Started by kenny h, April 01, 2013, 12:03:57 PM
kenny h
Predator
I have a single stalk on mine at the moment but want to put twin stalks so I can lose the wiper switch off the dash, mines a '71 chassis with IRS but not sure what column I have as the builder has obviously put a earlier front end on it with a beam.
Here's a couple of pics with the steering wheel off but I will have to put some up of the end of the column near the steering box to see what's what :-\
Any help or ideas appreciated as not sure where to start or go with this, for now I think I may just buy the wiper stalk and try and get it to fit if not may have to look at changing column!!  ??? :-\
Hunter
SDBC Moderator
CTR
Hi Mate.
Having a close look at the end of your column there and it seems that it did have a second stalk already it now has a wrap around cover over what used to be a twin stalk fitment.
Have a close look at what you got there, if you still got my number give me a call.
Cheers H
kenny h
Predator
Cheers H that's what I was thinking and hoping as I saw the cut out on the right hand side but wasn't sure if that was just were the ignition and steering lock went, now with the lighter evenings I will hopefully get round to having more of a chance to look at it this week but I can chat with you on Wednesday over a pint ;-)up
Hunter
SDBC Moderator
CTR
Quote from: kenny h on April 01, 2013, 06:38:21 PM
Mmmmmmmm  :o  ::)  ;)
;-)up ;-)up ;-)up
Mickyb
GP MK2 LWB
I think you are right it is for the lock to fit on the coloum I checked a spare that I had in my shed and took a photo.
kenny h
Predator
Cheers Mick, as i suspected... oh bugger :-[ :'(
Oh well back to the drawing board, could try and make something fit but don't think i've got the depth there :-\ ???
Hunter
SDBC Moderator
CTR
Kenny,
Elemental this weekend may be a source for a cheap column or just another surround.
Speak to you on Wed eve.
H
Doon SWB No.1 & No.2
A twin stalk setup won't fit on a single stalk column I'm afraid.
There is a tab on the column the cowling slides onto and it is in different locations on a single column compared to a double stalk column :-[
Best thing is to try and get a full column with teh twin stalks on it and simply change the whole column over on the buggy.
