Fuel tank vent
Started by BuggySteve, May 09, 2016, 05:58:45 PM
BuggySteve
Manxter 2+2 Dualsport
Hi my tank has a central relocated filler neck which now has a nice tight fitting cap ;-)up
However there's a very small pipe front near side. Is this for air venting? If so where do I route the pipe to? Washer hose would fit
Manxter Dualsport
Put a loop in it so it goes near the top of the bonnet underside then run it along the tank and down so it exots lower than the floor pan, screen was pipe will be ok as it will go hard with time.
BuggySteve
Cheers Snoopy :D
Manxter Dualsport
