Few inches of steel brake or fuel pipe needed
Started by Doon L001, November 13, 2015, 11:09:32 AM
As it says in the title I need a few inches of steel brake or fuel pipe, preferably a bit of new that is left over not an old bit as I want to weld it.
It has always smelt of fuel under the bonnet, and I have found out why. The air bleed is a piece of copper pipe brazed (badly) into the filler neck, I gave it a wobble and out it came, I would like to replace it with steel welded in.
Tank is out and fully dry, no smell of fuel, so all I need is a bit of pipe OD 7-8mm or thereabouts. 7 at the moment but I own a drill.
I can pay the postage plus Paypals cut no problem, anyone got an off cut?
I have a short length of brake pipe here - its the short 15" one
Its unused and still has the fittings on it - given it a scrape and its silver under the coating, so I guess steel not copper.
Only looks to be about 5mm OD though ?
Any use?
Thanks Dave, I will see if anyone else comes up with something nearer the size, if not I will give you a shout.
thanks
Dave just found a length of stainless 8mm outer what length do you need.
Snoopy, can I have about 4" please Snoops, no smutty comments needed from anyone else.
I only need a couple of inches but best have a bit extra as my welding isnt brilliant
Just PM and let me know what the postage is and a Paypal or I can buy you a pint at Stoneleigh or IBW
Address PMd
Got 5 inches with a rib one inch from an end so you can drill a hole then but the ridge up against the metal to weld around, only cost is a stamp so no worries as it goes in a standard envelope.
Thanks Snoopy that sounds perfect, although with that description I am amazed there have been no comical comments
Serious stuff only on here Dave after all we are all grown ups, went in the post box last night.
Quote from: snoopy on November 14, 2015, 09:14:27 PM
You on the right site?
Thanks a lot, I owe you one
Arrived this morning's post - cheers Snoopy, you're a hero
Good news then I thought it was light enough not to warrant anything special 2nd class stamp did work :D
Forgot to mention thanks Dave but Snoopys is bigger so I went for his  :o :o :o
All I have to do now is a bit of welding then see what it will cost to get the tank powder coated
