alloy rims
Started by poacher, October 13, 2015, 12:28:45 PM
poacher
lwb 1600.gp mk2 superbuggy
Still looking for nice shiny 4 stud alloy rims to replace my Weller 8 spoke front 6jx14 rims on 205/60 r14 tyres.
Rear Weller 8 spoke dished 10x15 rims on 275/60 15 tyres, 4x130 stud pattern,any body got any for sale or know where i can replace with new ?. cheers.
`SNAFU`
HUDGE BUGGY
GP Mk2 Super Buggy LWB
Thanks for that link ;-)up ;-)up, I'm watching them also, but being the resident expert on these rims, my question is:
How difficult will it be to get m14 studs to suit the rims, or is it better to convert to studs in the drum and use tapered nuts?? ??? ???
Your advice will be appreciated, not just by me, but by others in the same dilemma.
I've been on the wolfrace site and could not see anything that might suit.
Cheers
I swapped to studs BUT they come with part of the stud unthreaded and if you fit the wheels the nuts just reach the unthreaded bit giving you the false impression that you have the wheel nuts tight.
Fixed this with 1/2" spacers
I also had to grind the rear studs a little shorter as they fouled inside the rear drums
Just a couple of points to watch out for
Wolfrace use a shank bolt pretty sure they are 5/8" or 49/64th diameter as they did 2 size holes. Bolts afe hard to find I got a set with oversize shank then had them machined down to suit. The wheels are located by the shank and use a washer with a slight cone on. They have been discussed before so do a thread search.
Good point Snoopy, my wheels are 2 different styles and I had the smaller holes rebored to match the other wheels, only about 2 thou in it
HUDGE BUGGY
Cheers Dave and Snoopy, did a thread search within the forum and came out "computer says noooooooooooooooo"
Give us a clue guys, is less is more in the search mode ;-)up
HUDGE BUGGY
Found the thread and its seems they are like rocking horse poo,   M14 x 5/8 with the shoulder seem to be the most common, so decision time, do you buy the wheels and hopefully find the bolts ??? ??? or be happy with what ya got.
I guess you could use 12mm studs as they give you a greater thickness for the shank on the nut but You would need drums drilled for the 12 mm studs either screw in on splined knock in.
Cannot understand why there are so many wolfrace around with no bolts as they do not fit other rims.
Most studs are machined 20/20 and give a lot of clearance problems as mentioned.
However, Use these Type2 ones - they fit perfectly, and allow the nut to be tightened properly as they are split 30/10
https://www.vwheritage.com/shop/AC601SS26/stud-wheel-screw-in-m14x1-5-40mm-30mm-10mm/#esp_pg=2
Wolfrace M14x1.5 sleeved nuts and 30 degree washers are available from   http://grayston.biz/wheelnutspage.htm   part no: SN59
Badger
GP Ranchero
these guys also may be able to help with any issues with your nuts  :-X
http://www.speedshack.co.uk/Wheelnuts.htm
billa4x4
purple 1776 sidewinder
Have used these on mine done many miles and had no issues
http://www.machine7.com/product.php?xProd=1181&xSec=591
HUDGE BUGGY
 ;-)up Cheers guys for all that useful info as always  ;-)up
poacher
Thanks for the heads up and info on the wheels chaps,why cant things be simple,buy ,bolt on,away ya go !.
`SNAFU`
Merscury
Predator
I went through  this minefield 6 months ago when I changed to wolfrace slots and I contacted all the usual suppliers of custom wheel bolts/studs, the only guy who could come with anything was Maurice at Mr Tee. http://www.mistertee.co.uk/
There are 2 different sizes of bolt holes for wolfrace slots and they are actually 41/64 and 11/16 the taper in the hoLe is 30 degrees, the holes in mine were 41/64, 14 mm wheel bolts are no longer available new. The only off the shelf option was to have 14 mm X 12 mm reducing studs and wolfrace 12mm nuts with a 41/64 shank and 30 degree taper plus 41/64 washers also  with a 30 degree taper. The only person I found who could supply all of these from stock was Maurice at Mr Tee. See my build thread, ( Mercury's Predator )
Have fun. Be lucky
