Purple Flake Sidewinder with a few subtle touches..
Started by Baz, March 19, 2013, 09:57:43 PM
Inigo
Classic Manx
Baz
Glad you guys like the exhaust! In the process of sorting out the fuel supply, upgraded the stock outlet using a CSP piece:
Using 8mm line throughout which should be adequate for the engine's needs. This meant I had the tiny fuel line along the tunnel going spare, which ended up being ideal for the boost gauge signal. A new throttle cable is in place now and just needs a bracket on the carb to finish. I found some exhaust rubber mounts in the garage today, so that can be finished off now. The more I look at the buggy on axle stands the more I want to give it as much of a rake as possible, so will be going as large as possible on the rear (probably 35's, which is a shame as I just sold some, Jim still using them?) and a bit smaller upfront which means I should be able to lower the beam again. Have also started thinking about some designs for the audio install, unfortunately I'm due to go away with work again early next week, so that will be another 5 weeks of no progress.  :(
Big Clem
66 prowler
Still think your mad ;-)up keep up the good work :D
Baz
Flying out with work tonight, will be gone for 5 weeks so progress has ground to a halt again.  >:(
Enjoy the July weather!  :)
Baz
With my daily blowing its engine up (the van just about visible below) and then my second car bought as a winter daily blew its engine (another aircooled..) I've been pretty busy rebuilding engines. I have managed to finally get some buggy time in again though, the exhaust is now mounted:
I hadn't really thought this exhaust system through, the exhaust is less than 1m from the drivers/passengers ears..  :D
Moderator
Now isn't that funny..... Dave posts a photo of the RR jet engine and I bet I wasn't the only one thinking...
"I wonder how Baz is getting on..."
;-)up ;-)up
Steve
Street Predator
Baz
Was away for a while with work, here are the latest updates. Finally grew a pair and started the process of changing the wheels over to 10x15's.
New rear tyre on left:
On wheel:
On the buggy, before:
After:
Sticks out a bit.. :
Although that's not at the ride height, I'll be raising the rear by quite a bit.
New fronts next to old:
Fronts on the car..also stick out a bit:
I'm running adaptors at the moment, 1.5 inches at the front and 2 inches on the rear, am looking into getting some blank drums redrilled which should bring the wheels in a bit. May need to look into a narrowed beam too although I quite like the wide stance. Engine still isn't any further, I'm waiting on some bits to arrive from the US. Started looking at reverse rotation transfer cases with a view to fit the V8 directly over the gearbox, but I think I'll leave all that for a while.
8)
Baz
Big Clem
66 prowler
Now your wheels match you're engine foooking massive ;D ;D ;D ;D ;D looks good ;-)up
Steve
Street Predator
Quote from: Big Clem on January 07, 2014, 05:48:53 PM
got there before me  ;D
QuoteSticks out a bit.. :
Baz
Rolled the buggy out for some pictures. Rear has settled a lot lower than I was expecting, will raise it up.
There's only an inch between the rears and the body  >:(
Adaptors really need to come off, it's just too phat  :D
Steve
Street Predator
Doon SWB No.1 & No.2
Reminds me of those crazy fantastic Hot Wheels models.
Bonkers, brilliant but bonkers  :D :D :D
Steve
Street Predator
