Purple Flake Sidewinder with a few subtle touches..
Started by Baz, March 19, 2013, 09:57:43 PM
FireDancer
SWB GP Mark 1
I've seen cast alu ones for VW engines like that, but they wouldn't fit your engine.  ;D
Just visiting from BajaClub.  :D
BajaClub Bash organiser.
Baz
I'm sure they'd fit..just not on the engine  :D
A busy day today, started by shaping the top of the cover, and adding a chamfer to the leading edge of the fins:
I've left the bottom straight as the oil cooler will be mounted down there.
Next it got media blasted to give it a cast effect:
Fresh from the foundry!
I then took a quick break and fitted a new bugtech shifter to my single cab. The difference is amazing, it makes my Gene Berg in my other van feel like stock! I also fitted a hurst handle.
Back to the cover, I removed the "casting marks" on the fins with some 60, then 120, 180, 240 followed by 400. I followed that with some compound and here's the finished result:
I'm well pleased! It seems such a far fetched idea when the lengths of alu bar arrived, but it turned out better than I expected. The next step is drill some holes to mount this on it:
You may have noticed 2 of the studs were left long on one side, that's because the cover will also be used to mount the expansion tank:
Once all the holes are drilled and I've figured out how to mount it to the engine, the whole cover will be degreased and then laquered. That's tomorrow's job.  :D
