lifting bonnets
Started by muzzy01, July 15, 2015, 08:59:55 PM
muzzy01
lwb gt 2LTR 914 /lwb jas
MOULDS were made by MEL HUBBARD under licence of meyer manx, will fit many manx derived buggys, they are made to order in black or white gel coat
its a 3 part mould what you se is what you get minus the hinges
£250
MUZZY
Muzzzy,
Sorry for being thick. Will your bonnet fit a GP2 buggy, my windrsceen is an intergral part of the bonnet.
Paul
muzzy01
no bud you would have to add a wwindscreen
MUZZY
muzzy01
mm289
Predator
Hey Muzzy, have you got any pics of these fitted? I have a Predator with the headlights mounted on the wings
So am trying to figure out if the opening bonnet will clear these or if I have to relocate them to the bonnet and then have the pedestals on the wing empty?
Cheers,  ;-)up
Paul.
Predator 1600TP
1986 T25 Panel Van 1.9TD
1989 T25 Autosleeper 2.1 WBX (project)
1978 Late Bay Camper (even bigger poject)
1949 Dodge Business Coupe (older but better nick than the 'Bay!)
2008 Bullitt Mustang
muzzy01
#5
to use that size head lights you will have to mount them on the lifting bonnet, you could put indicators in the old headlight holes
MUZZY
muzzy01
this is the mould that MEL made with added lourvers
MUZZY
mm289
Predator
OK, thanks bud, I will have to have a think/look round at some photos.
Want to go with a lifting bonnet for access to electrics and fuel tank to make maintenance easier ideally......  :)
cheers,
Paul.
Predator 1600TP
muzzy01
my fuel tank split a couple years back wish i had a lifting bonnet then
MUZZY
Jonny
Shelbiette GT
Have you got any measurements for these?
Quote from: Jonny on November 16, 2016, 04:59:08 PM
Google Meyers Manx "Traditional Kick Out Buggy" and download the buggy build instruction manual. Doesn`t have precise dimensions but does show the bonnet, fixings, how to fit etc. Along with hinged back "hatch cover" that is available.  Believe this is the last  buggy version he will do and there are U tube video`s of the original built at quite a cost with I think a Subaru motor.
Kick Out bonnets hinge forwards, the ones that Muzzy sells hinge from the rear (stainless boat hinges work well).
Jonny
Shelbiette GT
Thanks, its just as mine isn't a mk1 GP/manx so trying to see if its close to fitting.
simon-dubman
I have one of these opening bonnets from Muzzy. My shell is from Mid Norfolk mouldings and was originally a Powerbug mould. There are two parts to the unit the dash panel that will need to be fibreglassed into your shell.
As my shell is of slightly different design i was surprised how well it fitted.  ;-)up
