Disc standard spindles
Started by BuggySteve, February 22, 2013, 10:26:51 PM
BuggySteve
Manxter 2+2 Dualsport
Hi all
I need a pair of standard disc spindles. Going to swap the dropped ones.
Anybody got any?
Cheers Steve
Manxter Dualsport
ben_w
Pair i saw the other day here........
http://www.volkszone.com/VZi/showthread.php?t=806087
Hunter
SDBC Moderator
CTR
Hi mate,
Think I have some, will check in the morrow.
H
Fatbuzzard
Modified powerbug, manta Ray & a predetermining
Ben at bens Bugshack has some, 07818119461  ;)
If I'm going to hell I'm going in a beach buggy 😜
Hunter
SDBC Moderator
CTR
Hi Mate
found em, wanna swop?
H
BuggySteve
I presume you will be at Volksworld to do the deal Hunter?  8)
Manxter Dualsport
Hunter
SDBC Moderator
CTR
Quote from: BuggySteve on February 23, 2013, 03:01:18 PM
Yep will be there just remind me near the time.....
if thats ok  ;)
H
BuggySteve
targabuggy
Doon Buggy
 :-\ :-\Why are you changing?????i have just bought dropped spindles to replace my standard spindles :-\ :-\
targa's are for tiddlers
BuggySteve
#9
1stly the drop is too low. Then I have 14'' fronts and the bottom arm is catching the rim. Then the calipers are fouling the dropped spindles. Lastly I'm going for adjusters as I can lower slightly the ride height on the bottom adjuster then just get the top one to the point of reducing the tension to soften the front. :)
Hope that makes sense
Steve
Manxter Dualsport
BuggySteve
Hi Hunter
Message sent
Manxter Dualsport
