To bump stop or not?
Started by Chris_e_86, January 18, 2014, 11:54:48 AM
Chris_e_86
Fibre fab
Seen a few things on here that some guys don't run with them an suggestions before I end end refurbing the brackets and replacing the stops it's on a 65 rat
Doon SWB No.1 & No.2
I would always run the rear bump stops as it does stop the rear wheel potentially rubbing up into the underneath of the wing and rubbing through (especially if you are carrying weight (in the car I mean :D).
This did happen to my old RAT years ago. So now I always run them.
Chris_e_86
Fibre fab
Thanks chad will get rubbing these brackets down quick question run urethane or original type rubber?
Doon L004
LWB Doon, L004-03
I would go with the original rubber as they are quite soft and work well
Chris
Chris : On the road since 2005
Chris_e_86
Fibre fab
Thanks guys will get some bumpys at dubfreeze and get the brackets panted up by then
