Throttle pedal pin
Started by ben_w, February 27, 2013, 10:50:56 AM
ben_w
Guys,
The throttle pedal is held in place by the 2"ish pin which slides into the bracket that is mounted to the floor pan.
What is it that is supposed to keep this pin in place? Having issues with mine coming out!
chrisbarker
lwb gt
Ben  there should be a under cut in the middle of the pin where the spring sits and this should stop pin from moving to far either way ;-)up
ben_w
Aha!!!
That makes some sense then. Ill have a look at the weekend as that throttle pedal spring from Hunter came today!
Thanks bud.
chrisbarker
lwb gt
your welcome ;-)up
Ben it is a wire butterfly spring where the pedal pin passes through a central loop.
ben_w
Cheers Snoopy.
I have one, H sent me one. Ill fit it at the weekend.
muzzy01
lwb gt 2LTR 914 /lwb jas
ill do one on the lathe if yours dont fit
MUZZY
