2165 FOR SALE
Started by kam663f, October 05, 2013, 06:34:16 AM
kam663f
For sale my 2165 which i had bought for my buggy but due to sad circumstances i have to part with some of my parts .
2165cc built by alan at gac in 2007 done approx 2000 miles since build
dynod at 167bhp at flywheel at 5,500 rpm
CC: 2165
BHP: 165
Case: AS41 Full Flow
Compression: 8.5;1
Crankshaft: Berg 78mm Forged and Welded
Flywheel: Berg Lightened and Balanced
Rods: Berg Balanced
Pulley: scat sand seal
Clutch Plate: stage 2
Clutch Disc: Stage 2
Barrels and Pistons: 94mm Mahle
Timing Gears: Berg Straight Cut
Cam Followers: scat
Camshaft: Web-Cam 86C
Pushrods: manton chrommoly
Oil Pump: bugpack with berg pressure releif cover
Sump: Berg Deep
Cylinder Heads: VW Speedshop CNC 44 re worked by alan at gac to flow better with matchported manifolds
Valves: 37.5 x 44
Springs: Dual
Retainers: berg
Rockers: Berg 1.4
Head Studs: 8mm Chromoly
Manifolds: Tall 48 ida
Header: 1.5/8 Stainless VW Speedshop
Muffler: speedshop
so basically you get the engine less tinware, carbs, linkage and dizzy.
engine as above £3300.00
it has consistantly run high 13's low 14's in a full weight street cal looker with a fat bastard (me) driving it. it runs strong and is happy pootling around town normally or going like a mad thing up the strip.
can be sold with carbs, linkage, fanhousing etc as turnkey(with a 009 pertronix instead of mallory dizzy) but i will want £4800 for that.
the only reason i am selling is foolishly i have the racing bug and am hunting lower times.... so rather than rip apart a perfectly good motor i am getting another one built. currently still in the car so can take serious buyers out for a spin (no test pilots though), can arrange delivery at extra £££
piccys showing the current install below....
car could also be for sale as is at the right price....
This image has been resized. Click this bar to view the full image.
The only differances  to the engine from when it was in the beetle i bout it from are
Linkage
Air filters
Ingnition system
Oil system
Altenator
thanks
pirate
me likey spec ,message sent,
i have a cunning plan :-)Geek
