Vacuum gauge
Started by Richard, September 13, 2013, 08:32:32 PM
Richard
GP MK11 1600cc
Hi, can any body please tell me if its possible to fit a vacuum gauge to a vw beetle engine, I put one on my mini about 40 year5s ago.
Richard
You can but they tend to be inaccurate due to the length of pipe required. TBH they weren't very good for anything except if you wanted to see a needle madly spinning round.
targed
Quite agree! Wy the hell would you want one? They perform no useful function.....
they tell you how much suck your engine has, vacum operated wipers were also a good indicator of that and they became extinct so enough said.
extra gauges that are useful are engine temp, rev counter, voltmeter/ammeter.
Richard
GP MK11 1600cc
Your right daft idea, I am fitting rev counter oil press oil temp ammeter and volt meter.
Quote from: Richard on September 14, 2013, 07:21:37 PM
You don't really need ammeter and volts, amps for dynamo and voltmeter for alternator IMHO, mind you you do't really NEED any of them... :-\
Richard
GP MK11 1600cc
Steve
Street Predator
Hazel
mk1 GP
I don't have any gauges!  ???
QuoteI don't have any gauges!   ???
Mmmm. well, you should have at least an oil temperature and pressure gauge....
The oil pressure warning light on a VW type1 engine uses a sender that only lets you know
when the pressure is below 6lb's/sq inch..... ???
Which is really a little low, specially when you might be cruising a motorway at 70!
I know you are very keen on invisible gauges but you really should have these two  ;-)up
Quote from: Hazel on September 15, 2013, 10:17:29 AM
Time to feel sorry for Hazel I will go an get my violin out ;D
BEELZEDUB
Moderator
Vulture???????
she could just mount some lights on a steering wheel boss or in the spokes if wanting a clean dash.
Hazel
mk1 GP
I guess that's true, I just haven't got around to it yet  ;D
There's still a to do list to get through!
targed
I think you'll find a speedo is a legal requirement for an mot now.....
Hazel
mk1 GP
Quote from: targed on September 15, 2013, 09:27:42 PM
Yes it is, and I had one for the MOT, now it's stupidly hidden away behind my dash.  ;D
