Steering Column Sleeve
Started by Sandrailer, May 20, 2013, 06:08:14 PM
Sandrailer
Sand Rail / Buggy
Hi guys, I am after the tube that the steering column sits in (With the bracket that mounts it to the dash)
In the Process of collecting parts for a Sand Rail Buggy. '67 Chassis and New frame under construction
You need to say what year column?  Is it the one with the key hole built in or the straight tube?
chrisbarker
lwb gt
Quote from: Roadrunner on May 20, 2013, 07:43:41 PM
also single or twin stalk
Sandrailer
Sand Rail / Buggy
I would say straight tube. Single stalk would work for me as I just need indicators. With no screen, no need for wipers  ;)
pilgrim 356
got one in the garage might help where in lynn are you as its were I work over at Gayton for the next 6 months cost nothing to try it then make an offer also got a ss outer as well thanks Pilgrim
