CB info...
Started by BugDream, February 23, 2013, 08:05:36 AM
BugDream
Peter,
I know you know loads on this subject. Shall we get the ball rolling?
Cheers,
Sam
Slow progress...
Eeerrrmm... Do I  ;)
I will look at taking some photos and put something together. It would be a good idea I think
Peter  :P
Hunter
SDBC Moderator
CTR
10-4
Rubber ducky
:D :D :D :D :D :D :D :D :D :D
BugDream
Ok, well here's a little to whet the appitite.
This is my CB
What else do I need to make it work? And where do I get the bits?
I know Peter goes to a particular website for parts/equipment, and we used to have all this kind of info on the old site...
Slow progress...
BEELZEDUB
Vulture???????
first you need to wire it in.
if it doesn't have a speaker then you'll need one of them,
an arial will also be needed and once fitted, use a swr meter to adjust it.
chrisbarker
lwb gt
will probably want a agp  (artificial ground plane ) as well as on fibreglass :)
Go here http://www.manxmaniac.co.uk/toolsAndIdeas-1.php
And look for 'CB Setup'  :)
BEELZEDUB
Vulture???????
Quote from: chrisbarker on February 24, 2013, 10:59:21 AM
forgot about that bit Chris ;)
