Axle gaiter clips
Started by Buggybaggy, November 10, 2026, 03:32:26 PM
Is it possible to fit these without the proper tool?
If so, how??
Or just use the old jubilee clips which are currently on?
You can hook them together and nail puller pliers will squeeze the crimping bit
Quote from: snoopy on November 10, 2026, 05:23:01 PMYou can hook them together and nail puller pliers will squeeze the crimping bit
Ioan Ford
Manx Meyer
I've used adjustable pipe/ plumber pliers and a flathead screwdriver. Open jaw wide but allow them to close enough to get the two mating ends to overlap sufficiently.  Don't be too greedy with the tightness when pushing the hook down onto the slot as the final crush you perform will pull the clamp together nicely.  Oh! And a nice dose of patience.  Always best to be in right frame of mind.
