Leaking swing axle side cover
Started by Ioan Ford, November 02, 2026, 06:51:56 PM
Ioan Ford
Manx Meyer
Hi all. At my wits end. Rebuilt my 1300 AB box with new shims, gaskets all meeting standard specs and settings. Ive got a gearbox oil leak coming from lower bolts on drivers side panel. All 6 bolts are really tight. I swapped the half shaft complete and guess what? Same problem!! What could it be? Ps- it's not the boot- it's the drivers side side cover leaking from bottom of the plate! Arghhhh!!
HUDGE BUGGY
GP Mk2 Super Buggy LWB
Have you used any sealant ?
Ioan Ford
Manx Meyer
No not yet. I saw some comments in the past stating that hymolar liquid gasket helps. It could be a last resort but I'd like it sealed the proper way if possible.  I appreciate that these items are old and there's wear and flex on some components. Sealant would mean draining, degreasing and drying thoroughly to get a good adhesion. Biggish job but I just might have to bite the bullet! The joys....!!!!
No sealant required. Have you used the correct number of gaskets ? Is the cover warped at all ?   Double check this. You should be able to seal these both sides with ease. (Always tighten the nuts down in a horizontally opposite fashion a bit at a time. No torque setting required just a gentle nip up.).
Ioan Ford
Manx Meyer
Thanks Paul.  Ill give it a try on the weekend! Wish me luck!!
HUDGE BUGGY
Quote from: Paul1953 on November 03, 2026, 09:14:37 AMNo sealant required.
Yeah right. How old are these parts ? And what damage is done by using it. ???
It`s a bodge Simply not required. If I can rebuild gearboxes without sealant so can anybody. Lost count of how many & never a leak.  9 years now since my buggy engine & gearbox was rebuilt. (1975 manufacture). Not a single drip from anywhere. It can be done.
HUDGE BUGGY
Old VW addage if it leaks its got oil
But point taken  ;-)up
