Swb prowler beach buggy
Started by Jbug61, May 03, 2026, 05:25:56 PM
Jbug61
swb prowler beach buggy 1971
Tax exempt
12 months mot (mot 2 may 2026
Red metal flake body and sidepods
Huge spec:-
Chassis and all suspension powder coated gloss black
Ball joint front, irs rear
2" roll cage powder coated
Dropped spindles with drilled discs and stock calipers
Rear discs drilled with mk3 golf calipers
S/s braided brake lines
Front wheels are Rocket racing Chevy bolt pattern 6x15 with 195x50x15 cooper cobras
Rear wheels are Rocket racing Chevy pattern 10x15 with 295x50x15 cooper cobras
Auto meter gauges
Steering column is 1302 with double jointed shaft mounted on flatlands column mount
Fully upholstered low back seats (flatlands)
4 point harnesses
Hydraulic clutch with modified pedals to position m/c next to brake m/c cnc slave cylinder
1776 engine:-
C/w crankshaft
Lightened flywheel
Equaliser front pulley
Deep sump
Remote oil filter and cooler with fan
S/S braided oil lines
Engle 120 cam with straight cut gears
CB perf 044 heads
Chrome moly pushrods
Bolt up rocker shafts
Twin 40 dellortos
Electronic ignition
Probably forgotten loads of other stuff any questions just ask
£12,500 Ono thanks for looking
JP61
Prowler is made by "east coast buggies". It is not a GP
Quote from: JP61 on May 23, 2026, 06:15:58 AMHello is this a GP MKI
It's a Prowler buggy fitted with the optional Manx style bonnet and dashboard.
