Raised Ball Joint Spindles ***SOLD***
Started by Dave DND, April 11, 2025, 08:49:32 AM
***SOLD***
Probably more for the Muddy Side than Buggies, but as they read this too, here goes
Now that I have changed my front end yet again, I have a nice pair of raised ball joint disc brake spindles that are now surplus to requirements.
These are a pair of Nathan Baker's finest, which means that they are fabricated  on the later genuine VW Stub axles with the larger 29mm spindle bearing giving around 2.5" of lift. They increase the track by about 10mm either side. Stamped and serial numbered, you can see why he has such a reputation for making these as they can only be described as bulletproof with some of the best welding you will ever see. Probably covered less than 200 miles and painted in blue hammerite.
£150 and collection from Paignton. Can stick on a DPD courier to UK mainland if required for additional £15.
***SOLD***
***SOLD***
