What fuse for an electric fuel pump?
Started by Doon L001, May 14, 2013, 07:19:40 AM
As the title says.
I will be running a fuel pump and cutoff valve from the fuse, I was thinking 10A, low enough to pop on a fault, high enough to not switch the fuel off in use.
Any comments?
Thanks, Dave
10A should be just fine
:-)Geek
thanks bDave, always good to get confirmation
